what do you guys use to screen your turbocharger with instead of a filter just a screen?
OK I have been through 2 slim fans and they quit working on me. So I have my stock fan back on now but its open with no screen or filter. what do you guys use to use this on your turbocharger?
I was thinking of window screen would this work
also could someone post pics of there screen they made.
thanks.
thanks.
some type of metal mesh type screen works well. Honestly there are lots of filters out there that can fit most applications. If its a daily driver i would not recommend a mesh screen unless its absoultly necessary.
well its a dd but I am waiting on my slim fan to get back and so the stock radiator fan is in the way so I cant put a filter there. I was just wondering would it be ok if I did something like a screen but what do you guys use to do yours
Check out what Xenocron has http://www.xenocron.com/catalo....html. Should work perfect for you.
the real question is why have 2 slim fans failed on you? did they just wear out or what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">the real question is why have 2 slim fans failed on you? did they just wear out or what?</TD></TR></TABLE>
exactly. my 1st slim fan went out because the heat from the manifold melted the wires. it was too close to the base/motor for me to fix so i just bought a new one and heat wrapped em...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homemadeturbo »</TD></TR><TR><TD CLASS="quote">I use an aluminum screen covered with a few layers of pantyhose or legging material. It works great.</TD></TR></TABLE>
exactly what I was looking for something like this. I wasent sure if people used pantyhose or not but that link someone on here that sent me a link to xenocron
I would like to get something like that to.
oh and by the way about the slim fan my tuner the way mine is set up is the tuner made my fan stay on all the time when my car is running and I took the fan out and nothing is melted but where the positive and the ground run to the fan its loose and well I sent it back.
Charlie Moua
Jun 21, 2003 06:47 PM
