Water on floor of passenger side of car after rain
Old Oct 30, 2007 | 10:53 AM
Mayorseed's Avatar
Default Water on floor of passenger side of car after rain
I have a 2003 Accord and the last 2 times it has rained I have had a lot of water on the rear passenger floor (about an inch). I assume it is a seal around the windo as the window has been closed but I do not see anywhere that the water is leaking in. What else should I be looking for?
Old Oct 30, 2007 | 04:09 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: Water on floor of passenger side of car after rain (Mayorseed)
use a flash light to check for holes in your firewall....did you happen to install some stero equipment recently????
Old Oct 31, 2007 | 06:28 AM
Heat's Avatar
Once the car is dry, sit inside and have a friend douse different parts of the car with a garden hose. Then have him rub the car with a soapy washcloth, then rinse the soap off.
Seriously though, you'll find out how water is entering with the garden hose.
Old Oct 31, 2007 | 09:02 AM
JimBlake's Avatar
Default Re: Water on floor of passenger side of car after rain (Heat)
Grommets on the firewall, or AC condensate drain, would put water on the FRONT floor. I think sunroof drain tubes would put water in the trunk.
If you can't figure it out with a garden hose, you may have to remove your carpeting. There's plugs in the floorpan from the factory. Maybe one fell out? That might only let water in when it's spraying around from the road.
In any case you'll want to remove the carpeting. If not, it'll take months to dry out. Do ya like the smell of mildew?
Old Nov 1, 2007 | 04:51 AM
Joose's Avatar
If you have a sunroff, blow compressed air down the drain tubes and listen inside the car.
kaboose79
Nov 22, 2016 07:43 AM
cmc600rr
Apr 11, 2010 11:21 AM
notasleeper
Jan 10, 2006 04:54 PM
StockTeg
Jun 24, 2003 12:27 PM
Arvid
May 11, 2003 08:35 AM
