my car turned into a lake
so basicly i have enough water in my trunk to go swimming. and this morning i got up and the passenger side of my car on the floor board was full of water too. i checked all the seals they look good, the windows were up. doors were shut all the way.
anyone else have any water problems? or could someone give me some help on fixing this.
thanks alot
thanks alot
was your car in a flood? If you wanna try and check your door seals just dry your car all around the seals first. Then get a water hose and a jet type hose attachment that really sprays water hard. Spray it around the edge of the doors & trunk to see where the water is leaking into the car. Maybe that will help.
no the car wasnt in a flood, that i know of anyway. its a 95 civic coupe. i just completely gutted the car i found no signs of water leaking in. and its pouring right now. its dry inside now so i just gonna go get the hose out and spray that motha down ans see what happens. i think i am just gonna go buy new seals tomarrow or later today.
oh also the other day i had the same problem so i took out everything and the walls of the trunks had alot of water on them, kinda like dew in the morning on the car. idk if that would cause as much water as i had in it though. the bottum of the trunk was completely full like past the spair tire. and the back seat was completely soaked also was the floor boards in the front of the car too.
Re: (notasleeper)
Does it have a sun/moon roof?
Integra's are known for having leaks cause of those. The drains run from each corner of the sunroof frame and the tubes run to the corners of the car and drain outside into the fenders.
Mine had a drain tube come loose, and I just had to reconnect it.
Re: (cdizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cdizzle »</TD></TR><TR><TD CLASS="quote">HE HAS A 1995 CIVIC NOT AN INTEGRA?</TD></TR></TABLE>
Yeah, but if it has a sunroof or moonroof, it can leak just the same. They all have drains and drain tubes.
Re: (Marauder)
I have the same problem, but mines a slow leak, only leaks in about every 2 days if its been raining a lot. You should check the drain hoses running into the trunk would be my first guess.... try having someone spray it with a hose or something and then lay down in your trunk with a flashlight. i did it this way to find my leak...
worst comes to worst u can buy lots of sponges and take them out every once an a while.
theres no sunroof or moonroof. and i have just been putting a towel in the place where the spair tires goes and its kinda helped so far. till it got completely soaked. oh well i guess. on to a new car. sence this one is dented up anyway now. after saturday night
dlenoxx
12-02-2010 12:05 PM
Mayorseed
11-01-2007 04:51 AM
