17x9 +45
First of all spacers are bad but if u REALLY have to have 9" wide wheels...you could in theory buy the Brembo brake setup for the DC5R and then get x9 wheels with a spacer. But thats a theory i dunno for sure 8" wide is possible with no spacer on the brembos but i have no idea about 9" wide wheels plus im fairly certain ur turning radius would decrease ever so slightly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phthalo »</TD></TR><TR><TD CLASS="quote">you'll need extended studs too</TD></TR></TABLE>
yes, use the hr spacers.
Don't take advice from people who have never tried what they're preaching.
17X9 +45 will fit fine themselves.
As for the tires, they should be okay, as long as you have your fender lip rolled inwards.
I guess that's what happens when you ask questions on the internet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nahonda04 »</TD></TR><TR><TD CLASS="quote">why do you want a 17x9 wheel on your car?
it wud look retarded, plus i dont think it can be done</TD></TR></TABLE>
A 17X8 +45 and a 17X9 +45 look almost identical, so what would look retarded? I don't understand the logic behind some of these posts..
yeah you CANNOT put 17x9.5 with a +38 offset int he rear hits the the lower trailing arm. I mean te wheel bolts on and all but it hits the arms whenyou lower the car back to the ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCL »</TD></TR><TR><TD CLASS="quote">
yes, use the hr spacers. </TD></TR></TABLE>
what is your logic for using spacers? You would be effectivley reducing offset..or is it for clearance reasons on the rear suspension? I ran 17 x8.5, 25 offset on my ep3 and never had any rubbing issues whatsover..cars ability to create negative camber is the most extreme of any I can think of..I have a BB6 now and fitted 16x8 +3 offet and it was a pita to roll and pull fenders..negative camber would have made the job a lot easier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burke420 »</TD></TR><TR><TD CLASS="quote">dont waste money on spacers... get the right wheels, and studs... youll put tooo much stresson the car suspension.. and the wheel will just break off!</TD></TR></TABLE>
Don't listen to people who don't know what they're talking about.
SPACERS will NOT CAUSE YOUR WHEELS TO BREAK OFF. I don't know where you would even come up with a theory like that.
Too much stress on the suspension?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan12288 »</TD></TR><TR><TD CLASS="quote">spacers are bad to put on do the research...</TD></TR></TABLE>
I don't really know what to say, other than Volkswagen.
stockegsix
Jan 13, 2005 03:39 AM
