Leaking clutch fluid (need help)
sometimes my clutch pedal gets stuck on the floor and dosnt let me go into gear and sometimes it just gets short. i checked my clutch fluid and i notice that its having less and less everytime i go fast. Where can it be leaking from?
check you clutch master cylinder and your clutch slave cylinder. If you look underneath you dashboard, your cluth pedal connects to the master cylinder. See if you notice any fluids.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LemonsEH2 »</TD></TR><TR><TD CLASS="quote">It"s definitly the slave cylinder.
you may not see the leak because the slave is covered by a boot. Shove the boot aside and stick your finger inside, it should be fairly dry if its not leaking.</TD></TR></TABLE>
tru dat, but you should definetaly check the master cylinder. Look at the interior firewall because mine was leaking. To be safe I replace that, the slave cylinder and the slave cylinder hard line. Took 30 minutes tops including bleeding the line
Civic Racer X 7
11
Aug 27, 2014 05:53 PM
DriveSideWays
Jul 4, 2004 05:07 AM
