need help
Old Aug 24, 2006 | 09:14 PM
7sins's Avatar
Default need help
I was driving my car in the freeway and i step on my clutch then it suddenly didn't come back up so i could get it in gear anyone know the problem.
Old Aug 24, 2006 | 09:21 PM
BOOSTED RIVAL's Avatar
Default Re: need help (7sins)
bleed your slave cylinder
Old Aug 24, 2006 | 10:28 PM
tpvang's Avatar
what kind of car? Clutch got caught in the carpet maybe?
Old Aug 24, 2006 | 11:06 PM
95 integra's Avatar
Default Re: need help (BOOSTED RIVAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVAL &raquo;</TD></TR><TR><TD CLASS="quote">bleed your slave cylinder</TD></TR></TABLE>
Do this, also check for leaking fluid. The clutch system is incredibly simple, so it shouldnt be that hard to figure it out. You have a clutch pedal, it attaches to the clutch master cylinder, which pumps fluid through a tube and hits up the slave cylinder. Thus, you only have 2 parts that you really have to worry about. Also, have you checked your fluid level? That will tell you real quick if its a leak or not. Also if the fluid is too low then fill it back up for a quick fix (given you have to fix the leak sooner or later).
Steviebix33
Aug 14, 2011 07:43 PM
jajackson
Nov 16, 2007 08:50 AM
VTECdohcter
Oct 30, 2007 04:31 AM
707EF8
Jul 29, 2006 08:09 PM
R.a.w.
May 18, 2005 03:41 PM
