gsr rebuild questions......
well i blew my motor, stock block didnt hold 15psi so i crack the slock sleeves, so now im doing a rebuild with a AEBS sleeved block from Iline Pro. Question is what gaskets/bearindgs do i need, i have purchase the following already.....
.....all from honda........
head gasket
intake gasket
exhaust gasket
rear main seal
front main crank seal
oil pickup gasket
oil pan gasket
rod baring (acl)
crank bearing (acl)
piston rings
head studs (arp)
thrush washer (acl)
am i missing anything????????
head gasket
intake gasket
exhaust gasket
rear main seal
oil pickup gasket
oil pan gasket
rod baring (acl)
crank bearing (acl)
piston rings
head studs (arp)
thrush washer (acl)
valve cover gasket kit. water pump. u dont really need oil unless yours is bad. those pumps are solid. shouldnt be a problem for reusing. if u have the tranny off then might as well do the oil seals too and the mainshaft seal. very cheap.
yeah as stated above, i have eagle rods now and my torque was at 230 and max on this graph is 316whp....... he couldnt find the other grph with 325 whp and i cant remeber the torque
Stacygifford
Jan 28, 2014 06:14 PM
AlphaKennyWun
Feb 13, 2002 04:47 PM
