IACV
Old Oct 26, 2007 | 04:53 PM
DrewMD's Avatar
Davis Photography
Default IACV
Shoot me now. I've been working on this for 6 months.
I have a 2000 Civic EX that I converted to a manual. I had to do the 2 wire IACV conversion, so I did. It worked fine until my bro mis-shifted. When I did wire it, I chopped it instead of de-pinning it.
So I soldered my connections after it acted up when my brother misshifted. It worked for a while now its acting up again. This time it will start fine and usually won't act up while cruising until I stop at a light. The car will idle up to 1500 rpm and sit there. Then when I drive adding and removing gas it will lurch. It will continue to do this until I restart the car. Then it will be fine for a while.
I ran a new solid wire to the IACV using a wire from a left over auto plug. This didn't change anything to my disbelief. So I did the same to the negative wire and instead of running it to the main relay or w/e it goes I just grounded it to the thermostat housing. It ended up making it worse, I don't understand how, so I changed it back.
please help before I get too sick of it.
-Drew
Old Oct 26, 2007 | 04:56 PM
i.'s Avatar
i.
are you sure its the IACv and not the TPS or something else?
https://honda-tech.com/zerothread/2127246
the search function comes in handy from time to time as well
Old Oct 26, 2007 | 05:01 PM
DrewMD's Avatar
Davis Photography
yes, I've searched. I know its the IACV.
Old Jan 2, 2008 | 09:19 PM
red-si-eg..'s Avatar
Default Re: (DrewMD)
its the tps. i miss shift in my hatch with a gsr in and i did all kinds of **** to it. new everything. but it turn out to be the tps jump. make sure ur tps volts is.50 at close. test the tps.
Brent1289
Feb 21, 2014 08:58 AM
boricuacivic
Apr 6, 2009 09:02 AM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
Pfieff
Dec 2, 2003 09:47 AM
