2k Si doors and climate control in a 97 Ek DX (hatch)
Old Oct 26, 2007 | 07:38 AM
Charltons_Trix's Avatar
Default 2k Si doors and climate control in a 97 Ek DX (hatch)
-yes, i DID search-
ok, i dont know exactly how hard it would be, but im purchasing a 2000 si shell for a great price, full interior. i want to know what i need to put the full door onto my car, so i can have power windows, power door locks, etc. how hard is it, wiring etc.
i also want to put the newer climate control into the dash, and wiring for that, i search about 5 times with differesnt descriptions and nothing came up.
thanks.
Old Oct 26, 2007 | 08:13 AM
hatch96y7's Avatar
Default Re: 2k Si doors and climate control in a 97 Ek DX (Charltons_Trix)
the doors are esy to do if u know how to do wiring and following diagrams.
but the climate control dont even wst ur time its to hard
Old Oct 26, 2007 | 08:18 AM
hatch96y7's Avatar
Default Re: 2k Si doors and climate control in a 97 Ek DX (hatch96y7)
<U>https://honda-tech.com/zerothread?id=605432</U>for the dash
and for the doors<U>https://honda-tech.com/zerothread?id=1762783</U>
Old Oct 26, 2007 | 09:58 AM
monicle's Avatar
dash- http://repo.jackmoves.com/v/erik/album106/album228/
doors- http://repo.jackmoves.com/v/erik/album106/album206/
for the doors you can make it all swap over but you will need to swap over the floor harenss, the rear main harness, and the dash harness. then everything will be plug and play. This would really be the easiest way since you will need to remove the dash completely anyways for the climate control swap.
the reason for this is the 2k floor harness main connections are different than that of the 96-98. luckily you have an entire donor car so you can just swap all the interior wiring completely.
Old Oct 27, 2007 | 05:06 PM
Default Re: 2k Si doors and climate control in a 97 Ek DX (monicle)
thanks, that will help a lot.
Old Oct 27, 2007 | 06:40 PM
Hybrid96EK's Avatar
I have the doors in my car. Used the interior harness from a 99 EX and had to make some small modifications. Also installed the keyless entry unit from the same EX to work with my power locks. Pretty slick little setup I might add.... And its even all OE.
Old Oct 29, 2007 | 10:00 AM
Default Re: 2k Si doors and climate control in a 97 Ek DX (Hybrid96EK)
i dunno if it has the keyless entry, i hope it does cas well, thats just baller. the shell was given to my friend, and i'm buying it from him, its a 00Si shell, and its supose to be in good condition.
Old Oct 29, 2007 | 01:45 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charltons_Trix &raquo;</TD></TR><TR><TD CLASS="quote">i dunno if it has the keyless entry, i hope it does cas well, thats just baller. the shell was given to my friend, and i'm buying it from him, its a 00Si shell, and its supose to be in good condition. </TD></TR></TABLE>
It will unless it was removed. It was standard on the '99-'00 Si.
Old Oct 29, 2007 | 05:50 PM
Hybrid96EK's Avatar
Default Re: 2k Si doors and climate control in a 97 Ek DX (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">
It will unless it was removed. It was standard on the '99-'00 Si.</TD></TR></TABLE>
yeah, it should have it. Drivers side kick panel in the floor by the hood release.
Old Oct 31, 2007 | 07:48 AM
i know it should have it, i'm saying i dont think it has the button u use to lock and unlock it, i think the guy lost it.
Old Oct 31, 2007 | 10:10 AM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charltons_Trix &raquo;</TD></TR><TR><TD CLASS="quote">i know it should have it, i'm saying i dont think it has the button u use to lock and unlock it, i think the guy lost it. </TD></TR></TABLE>
Just get one off ebay.. easy to program once you wire in the keyless entry module.
1991_HondaAcc
Jul 18, 2009 08:15 PM
young geezer
Nov 7, 2008 05:45 PM
172R42Type16888
12
Jan 10, 2004 07:44 PM
Mr Boston
20
Oct 9, 2003 05:33 PM
Mike Ockhurts
19
Mar 13, 2003 04:50 PM
