2k Si doors and climate control in a 97 Ek DX (hatch)
-yes, i DID search-
ok, i dont know exactly how hard it would be, but im purchasing a 2000 si shell for a great price, full interior. i want to know what i need to put the full door onto my car, so i can have power windows, power door locks, etc. how hard is it, wiring etc.
i also want to put the newer climate control into the dash, and wiring for that, i search about 5 times with differesnt descriptions and nothing came up.
thanks.
thanks.
Re: 2k Si doors and climate control in a 97 Ek DX (Charltons_Trix)
the doors are esy to do if u know how to do wiring and following diagrams.
but the climate control dont even wst ur time its to hard
Re: 2k Si doors and climate control in a 97 Ek DX (hatch96y7)
<U>https://honda-tech.com/zerothread?id=605432</U>for the dash
and for the doors<U>https://honda-tech.com/zerothread?id=1762783</U>
1 Post
dash- http://repo.jackmoves.com/v/erik/album106/album228/
doors- http://repo.jackmoves.com/v/erik/album106/album206/
for the doors you can make it all swap over but you will need to swap over the floor harenss, the rear main harness, and the dash harness. then everything will be plug and play. This would really be the easiest way since you will need to remove the dash completely anyways for the climate control swap.
the reason for this is the 2k floor harness main connections are different than that of the 96-98. luckily you have an entire donor car so you can just swap all the interior wiring completely.
I have the doors in my car. Used the interior harness from a 99 EX and had to make some small modifications. Also installed the keyless entry unit from the same EX to work with my power locks. Pretty slick little setup I might add.... And its even all OE.
Re: 2k Si doors and climate control in a 97 Ek DX (Hybrid96EK)
i dunno if it has the keyless entry, i hope it does cas well, thats just baller. the shell was given to my friend, and i'm buying it from him, its a 00Si shell, and its supose to be in good condition.
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charltons_Trix »</TD></TR><TR><TD CLASS="quote">i dunno if it has the keyless entry, i hope it does cas well, thats just baller. the shell was given to my friend, and i'm buying it from him, its a 00Si shell, and its supose to be in good condition. </TD></TR></TABLE>
It will unless it was removed. It was standard on the '99-'00 Si.
Re: 2k Si doors and climate control in a 97 Ek DX (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">
It will unless it was removed. It was standard on the '99-'00 Si.</TD></TR></TABLE>
yeah, it should have it. Drivers side kick panel in the floor by the hood release.
i know it should have it, i'm saying i dont think it has the button u use to lock and unlock it, i think the guy lost it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charltons_Trix »</TD></TR><TR><TD CLASS="quote">i know it should have it, i'm saying i dont think it has the button u use to lock and unlock it, i think the guy lost it. </TD></TR></TABLE>
Just get one off ebay.. easy to program once you wire in the keyless entry module.
172R42Type16888
12
01-10-2004 07:44 PM
Mr Boston
20
10-09-2003 05:33 PM
Mike Ockhurts
19
03-13-2003 04:50 PM
