will a b series ecu fit a d series car?
im just wondering if an ecu form a b16a2 engine will fit in my car, mines has a d15z8 vtec engine. iv been told by a few people that it will fit and work but im a bit unsure. just wanted to check before i go and buy 1
D15z8 ????
Don't you mean d15z1 or d16y8. Either way why would you want to do that. And if its a VX engine i say it's point less. That engine was never intead for run on all 16v at low rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big_dong861 »</TD></TR><TR><TD CLASS="quote">it is definetley a d15z8 vtec engine, got the number stamped on it and revs to 7200rpm standard</TD></TR></TABLE>
Wait are you from Europe?
Even though it stops making power at 6600rpm. Just buy a chipped p28 and have it tuned. Your not going to get anything by swapping a b16 ecu.
i didnt find that engine code bro u sure is a z8 here is what ive found on the net. on all d15s
[edit] D15 Series Engines (1.5 Liters)
[edit] D15A2
Found in:
1984-1987 Honda CRX DX
1984-1987 Honda Civic (JDM)
Displacement : 1488 cm³
Bore and Stroke : 74 mm X 86.5 mm
Compression : 9.6:1
Power : 76 hp (57 kW) @ 5500 rpm & 84 ft·lbf @ 3500 rpm
Valvetrain : SOHC 3 valves + 1 auxiliary valve for each cylinder
Fuel Control : Carbureted, CVCC
[edit] D15A3
Found in:
1985-1987 Honda CRX Si and 1987 Civic Si (AU/NZ)
Compression : 13.5:1
Power : 91 hp (68 kW) @ 5500 rpm & 93 ft·lbf @ 4500 rpm
Valvetrain : SOHC, 3 valves/cylinder
Fuel Control : Fuel Injected, Multi-point PGM-FI
[edit] D15B
VTEC
Found in:
1991-1999 Honda Civic VTi EG4 (Japanese Market)
Displacement : 1493 cm³
Bore and Stroke : 75 mm X 84.5 mm
Rod Length : 137 mm
Compression : 9.3:1
Power : 130 hp (97 kW) @ 6800 rpm & 102 ft·lbf @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-1 MPFI
[edit] D15B (with 3 stage VTEC)
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Rod Length : 137 mm
Compression : 9.3:1
Fuel Control : OBD-2 MPFI
[edit] D15B1
(Same as the D15B2 engine, but with a mild camshaft, and a restrictor plate between the throttle body and intake header)
Found in:
1988-1991 Honda Civic Hatchback
Bore and stroke : 75 mm X 84.5 mm
Compression : 9.2:1
Power : 70 hp (52 kW) @ 5500 rpm & 83 ft·lbf @ 3000 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : OBD-O DPFI
[edit] D15B2
Found in:
1988-1991 Honda Civic DX/DLX
1988-1991 Honda CRX DX
1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
Compression : 9.2:1
Power : 91 hp (68 kW) @ 6000 rpm & 119 Nm @ 4500 rpm
Fuel Control : PGMFI Dual Point
[edit] D15B4
Found in:
1989-1991 Honda Civic GL (Australian Market)
Compression : 9.2:1
Power : 90 hp (70 kW) @ 6000 rpm & 122 Nm @ 4500 rpm
Valvetrain : SOHC (2-4 valves per cylinder, depending on year)
Fuel Control : Dual Carburettor
[edit] D15B6
Found in:
1988-1991 Honda CRX HFx
Compression : 9.1:1
Power : 62 hp(88-89) 72 hp(90-91)@ 4500 & 83 ft·lbf @ 3000 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-0 MPFI
[edit] D15B7
Found in:
1992-1995 Honda Civic CX (Canadian model)
1992-1995 Honda Civic DX/LX
1993-1995 Honda Civic del Sol S
1992-1995 Honda Civic LSi Coupe (European Market)
Compression : 9.2:1
Power : 102 hp (76 kW) @ 5900 rpm & 98 ft·lbf @ 5000 rpm
[edit] D15B8
Found in:
1992-1995 Honda Civic CX (U.S. model)
Compression : 9.1:1
Power : 70 hp (52 kW) @ 4500 rpm & 83 ft·lbf @ 3000 rpm
[edit] D15Z1
VTEC-E
Found in:
1992-1995 Honda Civic VX
1992-1995 Honda Civic VEi (European Market)
Rod Length : 137 mm
Compression : 9.3:1
Power : 92 hp (69 kW) @ 5500 rpm & 97 ft·lbf @ 4500 rpm
VTEC Switchover : 2500 rpm
Valvetrain : SOHC VTEC-E (4 valves per cylinder)
[edit] D15Z4
Found in:
1996-2000 Civic Exi
Displacement : 1493 cm3
Power : 105 hp (78 kW) @ 5800 rpm
Torque (ft·lbf@rpm): 99 (135 N·m) @ 4,200 rpm
Valvetrain : SOHC
[edit] D15Z6
VTEC-E
Found in:
1996-2000 Honda Civic LS (European Market)
Rod Length : 137 mm
Compression : 9.6:1
Power : 114 hp (85 kW) @ 6500 rpm
Torque : 98 ft·lbf (141 Nm) @ 5400 rpm
VTEC Switchover : 2500 rpm (3500 rpm in 5th gear)
Fuel Control : PGM-FI MPFI
[edit] D15A2
Found in:
Compression : 9.6:1
[edit] D15A3
Found in:
[edit] D15B
VTEC
Found in:
Rod Length : 137 mm
Compression : 9.3:1
Redline : 7200 rpm
Fuel Cut : 7411 rpm
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.3:1
[edit] D15B1
Found in:
Compression : 9.2:1
[edit] D15B2
Found in:
Compression : 9.2:1
[edit] D15B4
Found in:
Compression : 9.2:1
[edit] D15B6
Found in:
Compression : 9.1:1
[edit] D15B7
Found in:
Compression : 9.2:1
[edit] D15B8
Found in:
Compression : 9.1:1
[edit] D15Z1
VTEC-E
Found in:
Rod Length : 137 mm
Compression : 9.3:1
[edit] D15Z4
Found in:
1996-2000 Civic Exi
Valvetrain : SOHC
[edit] D15Z6
VTEC-E
Found in:
Rod Length : 137 mm
Compression : 9.6:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michael123 »</TD></TR><TR><TD CLASS="quote">i didnt find that engine code bro u sure is a z8 here is what ive found on the net. on all d15s
It's a European version. It's not listed on Wikipedia
Here is a list of Euro
5th Gen (91-95) (EG) cc BHP Trq Top MPH 0-60 Engine USDM
Civic 1.3 3dr Hatchback 'Bali' 1343 75 ? 99 11 2 D13BL?
Civic 1.3 DX 3dr Hatchback 1343 75 ? 99 11 2 D13BL?
Civic 1.5 LSi 2dr Coupe 1493 102 98 118 9 8 D15B7 DX
Civic 1.5 LSi 3dr Hatch 1493 90 97 108 10 7 D15Z1 VX
Civic 1.5 LSi 4dr Saloon 1493 90 97 108 10 7 D15Z1 VX
Civic 1.5 VEi 3dr Hatchback 1493 90 97 113 10 D15Z1 VX
Civic 1.6 ESi 3dr Hatchback 1590 125 104 122 8 7 D16Z6 EX
Civic 1.6 ESi 4dr Saloon 1590 125 104 122 8 7 D16Z6 EX
Civic 1.6 VTi 3dr Hatchback 1590 160 112 133 7 4 B16A2
Civic 1.6 VTi 4dr Saloon 1595 160 112 133 7 4 B16A2
6th Gen (96-00) (EK) cc BHP Trq Top MPH 0-60 Engine USDM
Civic 1.4i Base 5dr Hatchback 1396 90 ? 111 13 1 D14A2?
Civic 1.4i 5dr Hatch Elec Pack 1396 90 ? 111 13 1 D14A2?
Civic 1.4i 3dr Hatchback 1396 90 ? 110 10 8 D14A2?
Civic 1.4i 'S' Hatchback 1396 90 ? 100 13 6 D14A4
Civic 1.5i LS 3dr Hatchback 1493 114 104 119 10 2 D15Z6
Civic 1.5i LS 4dr Saloon 1493 114 104 119 10 2 D15Z6
Civic 1.5i LS 5dr Hatchback 1493 114 104 119 10 2 D15Z6
Civic 1.5i VTEC-e 5dr Hatchback 1493 90 ? 112 13 D15Z8?
Civic 1.6i VTi 3dr Hatchback 1590 160 112 113 7 3 B16A2 Si
Civic 1.6i VTi 4dr Saloon 1590 160 112 113 7 4 B16A2 Si
Civic 1.6i ES 5dr Hatchback 1590 103 103 106 10 7 D16Y7
Civic 1.6i ES CVT 3dr Hatchback 1590 116 104 117 10 2 d16Y5 HX
Civic 1.6i LS 2dr Coupe 1590 105 103 118 10 2 D16Y7 DX
Civic 1.6i LS 5dr Hatchback 1590 105 103 118 10 2 D16Y7 DX
Civic 1.6i SR Hatchback 1590 126 107 112 9 9 D16Y8 EX
Civic 1.6i SR VTEC 2dr Coupe 1590 125 107 119 9 2 D16Y8 EX
Civic 1.6i 'Jordan' Hatchback 1590 160 ? 140 7 9 B16A2
Civic 1.6i VTi Coupe (99-00) 1595 158 116 140 7.9 B16A2
Civic 1.6i Type-R 1595 185 118 ? ? B16B
Civic 1.8i VTi 5dr Hatchback 1797 169 127 139 8 3 B18B
Civic 2.0i TD 5dr Hatchback 1994 86 ? 106 14 4 ?
Civic Aerodeck 1.5i LS 5dr Est 1493 115 ? 119 ? D15Z8
Civic Aerodeck 1.6i ES 5dr Est 1590 116 104 106 ? D16Y5
Civic Aerodeck 1.8i VTi 5dr Est 1797 169 139 ? B18C4
7th Gen (00-06) (EP) cc BHP Trq Top MPH 0-60 Engine USDM
Civic 1.4i E 3dr 1396 88 ? 110 11 5 D14Z6?
Civic 1.4i E 5dr 1396 88 ? 109 11 8 D14Z6?
Civic 1.4i S 3dr 1396 88 ? 110 11 5 D14Z6?
Civic 1.4i S 5dr 1396 88 ? 109 11 7 D14Z6?
Civic 1.4i SE 5dr 1396 88 ? 108 11 9 D14Z6?
Civic 1.6i VTEC 1590 108 ? 115 10 3 D16A1?
Civic 1.7i CDTi SE 3dr 1686 125 102 113 10 9 D17A9
Civic 1.7i CDTi SE 5dr 1686 125 102 113 11 1 D17A9
Civic 2.0i VTEC Type-R 1998 197 ? 146 6 6 K20A2
Civic 2.0i VTEC Type-S 1998 157 132 131 8 2 K20A3 Si
To the OP. Yes, it will fit but you'll probrably get a little or no performance increase. Worst possible case: The car will run like **** and get bad gas per mileage/kilometer.
thanks for your input anyway guys, il try it anyway coz im getting the ecu cheap, if it doesn't work il but a d16 ecu and chip it
Honded1
Engine Management and Tuning
16
Sep 18, 2016 03:21 AM
mayfly
22
Dec 21, 2008 10:48 AM
