will a b series ecu fit a d series car?
im just wondering if an ecu form a b16a2 engine will fit in my car, mines has a d15z8 vtec engine. iv been told by a few people that it will fit and work but im a bit unsure. just wanted to check before i go and buy 1
Re: (yoffer)
my ecu is restricted to 120 mph, not very good when ur killing golf gti's till the limmiter kicks in. the engine has everything else done to it so why not?
Re: will a b series ecu fit a d series car? (big_dong861)
D15z8 ????
Don't you mean d15z1 or d16y8. Either way why would you want to do that. And if its a VX engine i say it's point less. That engine was never intead for run on all 16v at low rpm.
Re: will a b series ecu fit a d series car? (kaiba)
it is definetley a d15z8 vtec engine, got the number stamped on it and revs to 7200rpm standard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big_dong861 »</TD></TR><TR><TD CLASS="quote">it is definetley a d15z8 vtec engine, got the number stamped on it and revs to 7200rpm standard</TD></TR></TABLE>
Wait are you from Europe?
Banned
Even though it stops making power at 6600rpm. Just buy a chipped p28 and have it tuned. Your not going to get anything by swapping a b16 ecu.
Re: will a b series ecu fit a d series car? (michael123)
i didnt find that engine code bro u sure is a z8 here is what ive found on the net. on all d15s
[edit] D15 Series Engines (1.5 Liters)
[edit] D15A2
Found in:
1984-1987 Honda CRX DX
1984-1987 Honda Civic (JDM)
Displacement : 1488 cm³
Bore and Stroke : 74 mm X 86.5 mm
Compression : 9.6:1
Power : 76 hp (57 kW) @ 5500 rpm & 84 ft·lbf @ 3500 rpm
Valvetrain : SOHC 3 valves + 1 auxiliary valve for each cylinder
Fuel Control : Carbureted, CVCC
[edit] D15A3
Found in:
1985-1987 Honda CRX Si and 1987 Civic Si (AU/NZ)
Compression : 13.5:1
Power : 91 hp (68 kW) @ 5500 rpm & 93 ft·lbf @ 4500 rpm
Valvetrain : SOHC, 3 valves/cylinder
Fuel Control : Fuel Injected, Multi-point PGM-FI
[edit] D15B
VTEC
Found in:
1991-1999 Honda Civic VTi EG4 (Japanese Market)
Displacement : 1493 cm³
Bore and Stroke : 75 mm X 84.5 mm
Rod Length : 137 mm
Compression : 9.3:1
Power : 130 hp (97 kW) @ 6800 rpm & 102 ft·lbf @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-1 MPFI
[edit] D15B (with 3 stage VTEC)
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Rod Length : 137 mm
Compression : 9.3:1
Fuel Control : OBD-2 MPFI
[edit] D15B1
(Same as the D15B2 engine, but with a mild camshaft, and a restrictor plate between the throttle body and intake header)
Found in:
1988-1991 Honda Civic Hatchback
Bore and stroke : 75 mm X 84.5 mm
Compression : 9.2:1
Power : 70 hp (52 kW) @ 5500 rpm & 83 ft·lbf @ 3000 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : OBD-O DPFI
[edit] D15B2
Found in:
1988-1991 Honda Civic DX/DLX
1988-1991 Honda CRX DX
1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
Compression : 9.2:1
Power : 91 hp (68 kW) @ 6000 rpm & 119 Nm @ 4500 rpm
Fuel Control : PGMFI Dual Point
[edit] D15B4
Found in:
1989-1991 Honda Civic GL (Australian Market)
Compression : 9.2:1
Power : 90 hp (70 kW) @ 6000 rpm & 122 Nm @ 4500 rpm
Valvetrain : SOHC (2-4 valves per cylinder, depending on year)
Fuel Control : Dual Carburettor
[edit] D15B6
Found in:
1988-1991 Honda CRX HFx
Compression : 9.1:1
Power : 62 hp(88-89) 72 hp(90-91)@ 4500 & 83 ft·lbf @ 3000 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-0 MPFI
[edit] D15B7
Found in:
1992-1995 Honda Civic CX (Canadian model)
1992-1995 Honda Civic DX/LX
1993-1995 Honda Civic del Sol S
1992-1995 Honda Civic LSi Coupe (European Market)
Compression : 9.2:1
Power : 102 hp (76 kW) @ 5900 rpm & 98 ft·lbf @ 5000 rpm
[edit] D15B8
Found in:
1992-1995 Honda Civic CX (U.S. model)
Compression : 9.1:1
Power : 70 hp (52 kW) @ 4500 rpm & 83 ft·lbf @ 3000 rpm
[edit] D15Z1
VTEC-E
Found in:
1992-1995 Honda Civic VX
1992-1995 Honda Civic VEi (European Market)
Rod Length : 137 mm
Compression : 9.3:1
Power : 92 hp (69 kW) @ 5500 rpm & 97 ft·lbf @ 4500 rpm
VTEC Switchover : 2500 rpm
Valvetrain : SOHC VTEC-E (4 valves per cylinder)
[edit] D15Z4
Found in:
1996-2000 Civic Exi
Displacement : 1493 cm3
Power : 105 hp (78 kW) @ 5800 rpm
Torque (ft·lbf@rpm): 99 (135 N·m) @ 4,200 rpm
Valvetrain : SOHC
[edit] D15Z6
VTEC-E
Found in:
1996-2000 Honda Civic LS (European Market)
Rod Length : 137 mm
Compression : 9.6:1
Power : 114 hp (85 kW) @ 6500 rpm
Torque : 98 ft·lbf (141 Nm) @ 5400 rpm
VTEC Switchover : 2500 rpm (3500 rpm in 5th gear)
Fuel Control : PGM-FI MPFI
[edit] D15A2
Found in:
Compression : 9.6:1
[edit] D15A3
Found in:
[edit] D15B
VTEC
Found in:
Rod Length : 137 mm
Compression : 9.3:1
Redline : 7200 rpm
Fuel Cut : 7411 rpm
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.3:1
[edit] D15B1
Found in:
Compression : 9.2:1
[edit] D15B2
Found in:
Compression : 9.2:1
[edit] D15B4
Found in:
Compression : 9.2:1
[edit] D15B6
Found in:
Compression : 9.1:1
[edit] D15B7
Found in:
Compression : 9.2:1
[edit] D15B8
Found in:
Compression : 9.1:1
[edit] D15Z1
VTEC-E
Found in:
Rod Length : 137 mm
Compression : 9.3:1
[edit] D15Z4
Found in:
1996-2000 Civic Exi
Valvetrain : SOHC
[edit] D15Z6
VTEC-E
Found in:
Rod Length : 137 mm
Compression : 9.6:1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michael123 »</TD></TR><TR><TD CLASS="quote">i didnt find that engine code bro u sure is a z8 here is what ive found on the net. on all d15s
It's a European version. It's not listed on Wikipedia
Here is a list of Euro
5th Gen (91-95) (EG) cc BHP Trq Top MPH 0-60 Engine USDM
Civic 1.3 3dr Hatchback 'Bali' 1343 75 ? 99 11 2 D13BL?
Civic 1.3 DX 3dr Hatchback 1343 75 ? 99 11 2 D13BL?
Civic 1.5 LSi 2dr Coupe 1493 102 98 118 9 8 D15B7 DX
Civic 1.5 LSi 3dr Hatch 1493 90 97 108 10 7 D15Z1 VX
Civic 1.5 LSi 4dr Saloon 1493 90 97 108 10 7 D15Z1 VX
Civic 1.5 VEi 3dr Hatchback 1493 90 97 113 10 D15Z1 VX
Civic 1.6 ESi 3dr Hatchback 1590 125 104 122 8 7 D16Z6 EX
Civic 1.6 ESi 4dr Saloon 1590 125 104 122 8 7 D16Z6 EX
Civic 1.6 VTi 3dr Hatchback 1590 160 112 133 7 4 B16A2
Civic 1.6 VTi 4dr Saloon 1595 160 112 133 7 4 B16A2
6th Gen (96-00) (EK) cc BHP Trq Top MPH 0-60 Engine USDM
Civic 1.4i Base 5dr Hatchback 1396 90 ? 111 13 1 D14A2?
Civic 1.4i 5dr Hatch Elec Pack 1396 90 ? 111 13 1 D14A2?
Civic 1.4i 3dr Hatchback 1396 90 ? 110 10 8 D14A2?
Civic 1.4i 'S' Hatchback 1396 90 ? 100 13 6 D14A4
Civic 1.5i LS 3dr Hatchback 1493 114 104 119 10 2 D15Z6
Civic 1.5i LS 4dr Saloon 1493 114 104 119 10 2 D15Z6
Civic 1.5i LS 5dr Hatchback 1493 114 104 119 10 2 D15Z6
Civic 1.5i VTEC-e 5dr Hatchback 1493 90 ? 112 13 D15Z8?
Civic 1.6i VTi 3dr Hatchback 1590 160 112 113 7 3 B16A2 Si
Civic 1.6i VTi 4dr Saloon 1590 160 112 113 7 4 B16A2 Si
Civic 1.6i ES 5dr Hatchback 1590 103 103 106 10 7 D16Y7
Civic 1.6i ES CVT 3dr Hatchback 1590 116 104 117 10 2 d16Y5 HX
Civic 1.6i LS 2dr Coupe 1590 105 103 118 10 2 D16Y7 DX
Civic 1.6i LS 5dr Hatchback 1590 105 103 118 10 2 D16Y7 DX
Civic 1.6i SR Hatchback 1590 126 107 112 9 9 D16Y8 EX
Civic 1.6i SR VTEC 2dr Coupe 1590 125 107 119 9 2 D16Y8 EX
Civic 1.6i 'Jordan' Hatchback 1590 160 ? 140 7 9 B16A2
Civic 1.6i VTi Coupe (99-00) 1595 158 116 140 7.9 B16A2
Civic 1.6i Type-R 1595 185 118 ? ? B16B
Civic 1.8i VTi 5dr Hatchback 1797 169 127 139 8 3 B18B
Civic 2.0i TD 5dr Hatchback 1994 86 ? 106 14 4 ?
Civic Aerodeck 1.5i LS 5dr Est 1493 115 ? 119 ? D15Z8
Civic Aerodeck 1.6i ES 5dr Est 1590 116 104 106 ? D16Y5
Civic Aerodeck 1.8i VTi 5dr Est 1797 169 139 ? B18C4
7th Gen (00-06) (EP) cc BHP Trq Top MPH 0-60 Engine USDM
Civic 1.4i E 3dr 1396 88 ? 110 11 5 D14Z6?
Civic 1.4i E 5dr 1396 88 ? 109 11 8 D14Z6?
Civic 1.4i S 3dr 1396 88 ? 110 11 5 D14Z6?
Civic 1.4i S 5dr 1396 88 ? 109 11 7 D14Z6?
Civic 1.4i SE 5dr 1396 88 ? 108 11 9 D14Z6?
Civic 1.6i VTEC 1590 108 ? 115 10 3 D16A1?
Civic 1.7i CDTi SE 3dr 1686 125 102 113 10 9 D17A9
Civic 1.7i CDTi SE 5dr 1686 125 102 113 11 1 D17A9
Civic 2.0i VTEC Type-R 1998 197 ? 146 6 6 K20A2
Civic 2.0i VTEC Type-S 1998 157 132 131 8 2 K20A3 Si
To the OP. Yes, it will fit but you'll probrably get a little or no performance increase. Worst possible case: The car will run like **** and get bad gas per mileage/kilometer.
thanks for your input anyway guys, il try it anyway coz im getting the ecu cheap, if it doesn't work il but a d16 ecu and chip it
Honded1
Engine Management and Tuning
16
09-18-2016 03:21 AM
mayfly
22
12-21-2008 10:48 AM
