where to set my adjustable cam gears on ls vtec for good results
I remember a while back reading about timing cam gears but I can not find it so if anyone can help? thanks
Set them at 0,0 until you're able to utilise a dyno to determine the effects your changes are having on the power curve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Set them at 0,0 until you're able to utilise a dyno to determine the effects your changes are having on the power curve. </TD></TR></TABLE>x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow »</TD></TR><TR><TD CLASS="quote">x2</TD></TR></TABLE>
Just wondering, do honda cams, have a slight advance/retard ground into them(when setup at zero) anyways like alot of dumbmestic cams??
radeon
Nov 22, 2004 07:24 AM
