tuning
Old Jun 23, 2004 | 10:13 AM
leew's Avatar
Default tuning
I have a b16a2 and I am trying to tune it better, right now I have just an intake header, cat and exhaust, and cam gears. Right now I have both cam gears advanced ten deg. Just looking for similiar set ups and what your gears are set at. maybe even those who have hp results from a dyno or times from track
Old Jun 23, 2004 | 10:15 AM
Rtype16's Avatar
Default Re: tuning (leew)
Did you say ten degrees holy crap. You probably aren't making the best power like that unless you cam gears are installed a tooth off.
Old Jun 23, 2004 | 10:38 AM
N2O's Avatar
N2O
Default Re: tuning (Rtype16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rtype16 &raquo;</TD></TR><TR><TD CLASS="quote">Did you say ten degrees holy crap.</TD></TR></TABLE>
I will second that!
Old Jun 23, 2004 | 10:42 AM
9seccivicsi's Avatar
Default Re: tuning (N2O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N2O &raquo;</TD></TR><TR><TD CLASS="quote">
I will second that!</TD></TR></TABLE>
i third that... that is way to much!
Old Jun 23, 2004 | 10:58 AM
leew's Avatar
well can I get some help then? I understand it is too much.
Old Jun 23, 2004 | 11:09 AM
crazykid's Avatar
stock cams... im thinking 0 will be about perfect, but im not expert... I could see maybe +1 on he intake side.. but thats about it.
But again, wait for some of the experts to come on tell you. For the best results, hit a dyno.
Old Jun 23, 2004 | 03:10 PM
RI_TM's Avatar
Default Re: (crazykid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazykid &raquo;</TD></TR><TR><TD CLASS="quote">stock cams... im thinking 0 will be about perfect, but im not expert... I could see maybe +1 on he intake side.. but thats about it.
But again, wait for some of the experts to come on tell you. For the best results, hit a dyno.</TD></TR></TABLE>
i agree with crazykid.
Old Jun 23, 2004 | 04:54 PM
SpeedDreamz.com's Avatar
Default Re: (RI_TM)
10 degrees cam timing? Dayumm.
Old Jun 23, 2004 | 07:10 PM
Group Tenacity's Avatar
A friend of mine didnt noe what he was doin when he adjusted his cam gears. he adjusted to +6 intake and -6 exhaust cuz he read somewhere on clubsi.com that, that would be the best way to make power.. Unfortunately, on his cam gears, each line was 2 degrees not 1 and every valve was bent when he started it up.. He drove it like that for 2 weeks wondering why his car was running like crap..
My advice is dont adjust cam gears unless you noe what you are doing, and are tuning them on a dyno. Just because something works on someone elses car, dont mean it will work on yours since all cars are differant.
Mike..
Old Jun 24, 2004 | 08:10 AM
JerseySiPOS's Avatar
Default Re: tuning (Group Tenacity)
i agree that if you dont know your cam gears or dont understand timing too well, you really dont wanna mess with that.
on the other hand, since you have cam gears, and if you want to experiment, try -2, -2 on the gears with 18 timing. most combinations with b16 cams and 0, 0 on the cam gears cause max pressure alittle early in crank degrees.
This was just an example of someone's setup that worked to give more top end and maintaining mid range.
Old Jun 24, 2004 | 10:43 PM
leew's Avatar
Default Re: tuning (JerseySiPOS)
thanks guys set my cams back at zero and my ignition at eighteen. runs great. a lot better top end. I actually found out tonight that a equal shift with the cam gears like +5 and +5 will shift the powerband.
layedoutat0psi
11
Nov 11, 2007 10:20 PM
DA_JDM
Jun 3, 2007 06:37 PM
AZNBIGPIMPN505
Nov 30, 2004 09:24 AM
radeon
Nov 22, 2004 07:24 AM
TintmanBr
Dec 16, 2003 07:52 PM
