b18c1 into 95 civic ex
Old Oct 23, 2007 | 04:36 PM
droppedeg6hatch's Avatar
Default b18c1 into 95 civic ex
just picked up a 95 gsr motor that came out of a 93 honda civic hatchback... dont get the ecu with it but otherwise is the motor plug and plug no need to change any pins in the ecu? any help would be really appreciated...
Old Oct 23, 2007 | 06:00 PM
Lscivic1999's Avatar
Default Re: b18c1 into 95 civic ex (droppedeg6hatch)
both obd1 so it should just plug and play
Old Oct 23, 2007 | 06:03 PM
EGmikeH22's Avatar
* B A N N E D *
except for how your ECU doesn't have the right code for that engine.
it'll run, vtec will work, but your secondary butterflies won't work, and your fuel maps will be all off.
so get a GSR ECU, or convert yours.
Old Oct 23, 2007 | 06:04 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: b18c1 into 95 civic ex (Lscivic1999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lscivic1999 &raquo;</TD></TR><TR><TD CLASS="quote">both obd1 so it should just plug and play</TD></TR></TABLE>Not totally true. You still have to run wires for knock sensor.
Old Oct 23, 2007 | 08:30 PM
Default Re: b18c1 into 95 civic ex (NVturbo)
secondary butterflies- i didnt think that b series had those thought only h22's did and for the knock sensor i have swapped a b18b1 into my old hatch and it was plug and play- do dohc vtec motors normally have knock sensors and a dohc non-vtec not have it? but besides running a knock everything else should work fine as far as you know?
Old Oct 24, 2007 | 05:37 PM
NVturbo's Avatar
O.G. triple O.G.
B18c1 is the only B-series motors that have knock sensors and secondary butterflies (that can be removed). You can find the knock sensor wire at the driver's side plug @ the shock tower location. B18b1 (LS, non-VTEC motors DO NOT have knock sensors)
Old Oct 24, 2007 | 09:01 PM
the gsr motor that i am running does not have a b18c1 intake manifold on it... im not sure exactly what the manifold is but it isnt the wierd looking stock one.... so i have to wire the knock sensor in and then the rest is plug and play
Old Oct 24, 2007 | 09:21 PM
94c1v1cex's Avatar
the p28 that you have in the car now will not look for a knock sensor... you will need to have the ecu socketed and then get a chip burned with b18c fuel/timing maps on it. and you'll be set.
if you use a gsr ecu i believe the knock sensor goes in d3... correct me if i'm wrong
Old Oct 29, 2007 | 09:02 AM
Default Re: (EGmikeH22)
quick question the harness on my b18c1 is all hacked up- could i just use my stock z6 harness on it then wire knock sensor depending on what ecu i decide to use?
Old Oct 29, 2007 | 09:06 AM
egsleepercivic's Avatar
Default Re: (droppedeg6hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedeg6hatch &raquo;</TD></TR><TR><TD CLASS="quote">quick question the harness on my b18c1 is all hacked up- could i just use my stock z6 harness on it then wire knock sensor depending on what ecu i decide to use?</TD></TR></TABLE>
yes
Old Oct 29, 2007 | 04:41 PM
Default Re: (egsleepercivic)
does the z6 harness have all the same plugs as the gsr? and is the length of the harness the smae also?
Old Oct 29, 2007 | 07:34 PM
if you seperate the O2 wires from the loom(do not cut), you should be able to make them reach, this is what I did when i put my z6 harness on my b16a, the z6 harness doe not have plugs for knock or IAB
gl
Old Nov 1, 2007 | 06:49 AM
the stock z6 harness has IAB plugs im pretty sure- just not the IAB plug for the secondary butterflies- but i am not running a c1 manifold so i could just use the stock iab plug on the z6 harness
Old Nov 1, 2007 | 05:28 PM
there is no IAB plug on a z6 harness, sorry
Old Nov 5, 2007 | 05:57 AM
your right- maybe im thinkin of the EVAP Sensor on the back of the z6 IM that sensor looks like a IAB right- well anyways since its not a c1 manifold i can just plug and play the stock z6 harness and then run knock sensor right
Old Nov 5, 2007 | 02:45 PM
yep
Old Nov 7, 2007 | 08:38 AM
thanx for all your help ill let you know how the swap goes if i have any more questions ill make sure to ask
whitehf
Oct 19, 2011 11:41 AM
diyeealooen
19
Aug 7, 2010 06:04 PM
turboturd98
11
Mar 13, 2004 02:08 PM
(JON)
Dec 3, 2003 06:05 AM
civictypenos
Aug 22, 2003 11:56 AM
