do you have to plug up the knock sensor hole?
using a newer motor in a older crx,im sure you dont have to but id like to make sure,rhw knock sensor did not come on the motor,so theres a hole there now.
Re: do you have to plug up the knock sensor hole? (civictypenos)
what ecu are you running ? are you running obd1 ?
if not and your motor and setup with ecu dont required it then you can just plug it up .
Re: do you have to plug up the knock sensor hole? (Spoon1)
obd 0,so i have no wiring for it,but the actual sensor id missing from the block(y7),so there is just a hole there,i was needing to know if i need to put a plug in there,i think its just a hollow cavity,but wanted to make sure there where no fluids that would be coming out of that hole.
