Flickering oil light...
Old Oct 23, 2007 | 02:35 PM
TDogg Teg's Avatar
Default Flickering oil light...
Sup, guys! Was sitting at a stop light the other day, and my oil pressure light started flickering at idle, and went out when I pulled off. Doesnt do it when the engine's cold when the oil temperature is low, just when it has time to heat up after a drive. Sometimes it doesnt go out when the car is revved again, sometimes it blinks. I think it's the oil pump.
The car has 250k on it, and I think its time for one anyway. Should have done it when I put my new head on along with timing belt and water pump. My sending unit is new, but I havent checked the pan screen yet.
Old Oct 23, 2007 | 02:42 PM
TDogg Teg's Avatar
Default Re: Flickering oil light... (TDogg Teg)
Oh yeah, its a 93 Accord SE.
Old Oct 23, 2007 | 03:56 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
have you checked tho oil level recently????
Old Oct 23, 2007 | 04:17 PM
TDogg Teg's Avatar
Default Re: Flickering oil light... (I got the CD5 Jeebies!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">have you checked tho oil level recently???? </TD></TR></TABLE>
I check my oil every other day. And it doesnt burn oil given the high mileage motor. Thats why I left that option out.
Old Oct 23, 2007 | 08:54 PM
not trying to be an *** but you haden't stated otherwise but I would venture its your oil pump
Old Oct 24, 2007 | 06:49 AM
toyorotor's Avatar
most likely its your oil pump...mine did the same thing and i ignored it, until it spun a bearing and through the rod...... change it soon!!!
Old Oct 24, 2007 | 12:53 PM
TDogg Teg's Avatar
Default Re: (toyorotor)
Im on it...
Old Oct 24, 2007 | 01:34 PM
Honda-Master's Avatar
Default Re: (TDogg Teg)
WOOOOOO.. TIME OUT HERE........ before you spend money on replacing an oil pump,, I strongly suggest that you chk the oil pressure ..
You need to properly diagnose before you start replacing parts...
Old Oct 25, 2007 | 12:31 PM
TDogg Teg's Avatar
Default Re: (Honda-Master)
And what psi am I looking for in cold and operating temps approximately? Gonna do it this weekend.
Old Oct 25, 2007 | 01:21 PM
engine at normal oper temp ( warmed up ) \\
idle minimum 10 psi
at 3000 rpm minimum 50 psi
if out of specs then i would chk the oil pump
if within specs i would replace the oil pressure sending unit , use a Honda part
Old Oct 25, 2007 | 01:24 PM
Chiovnidca's Avatar
And quit driving it till you find out what's going on.
Old Oct 26, 2007 | 11:57 AM
TDogg Teg's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">And quit driving it till you find out what's going on.</TD></TR></TABLE>
It's been parked since it happened. Dont wanna spin a bearing.
Old Oct 26, 2007 | 12:05 PM
TDogg Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Master &raquo;</TD></TR><TR><TD CLASS="quote">engine at normal oper temp ( warmed up ) \\
idle minimum 10 psi
if within specs i would replace the oil pressure sending unit , use a Honda part</TD></TR></TABLE>
Gotcha.
Sending unit is new (bout a couple weeks old, replaced it when I put the head, head gasket, timing belt and water pump on), but its from AutoZone. But after the check, and if everythings ok, I'll pick up an OEM one from Colonial Honda up the street. I'll feel more comfortable.
Old Oct 30, 2007 | 01:17 PM
TDogg Teg's Avatar
Update: Pressure checked ok (although a little low at idle). Replaced the AutoZone unit with an OEM honda unit...no more flicker!
Thanks, guys.
Old Oct 30, 2007 | 01:54 PM
radiuslight's Avatar
Yep
just my 2 cents
for 90-93 accords all sensors must be OEM from honda
or else they just fall apart or burn out within months
just my experience
93 accord LX
acuraman08
Apr 3, 2008 07:04 PM
soon2bdropped
Dec 10, 2006 01:20 PM
DC_RaceR
Feb 23, 2006 02:00 PM
an2ny888
Apr 3, 2004 03:10 PM
toooslow
Jul 8, 2003 10:59 PM
