gsr knock sensor stays on!!!
Old Oct 22, 2007 | 08:17 PM
dc2_97teg's Avatar
Default gsr knock sensor and o2 sensors stays on!!!
Ok, so here's the deal... I have a 1997 integra rs... and blew a whole in cylinder #1 about a few months ago. So i picked up a 1998 gsr motor and dropped it in my car a month after blowing my last one. After installing my motor... i noticed that i have 3 check engine lights that remain on. I have code 23,41,65. I checked the wiring on my o2 sensors and my knock sensors... and they are in their corresponding spots. So i reseted my ecu and unplugged my battery... hook everything back on... and i turn the key to the on switch without turning "on" the car. So the first things that pop back up are my o2 sensors... but my knock sensor is cleared... but as soon as i turn my car on... i drive it down the street at 25 mph and then the knock sensor light comes back on... i know the motor didn't have a knock code before.. cause the owner of the gsr was my cousin.... so yea... if anyone could help me please inform me!!!
Old Oct 22, 2007 | 08:19 PM
all-mtr-teg's Avatar
Default Re: gsr knock sensor and o2 sensors stays on!!! (dc2_97teg)
what gas are you running? High octane?
Old Oct 22, 2007 | 08:20 PM
dc2_97teg's Avatar
Default Re: gsr knock sensor and o2 sensors stays on!!! (all-mtr-teg)
well when i put the motor in... i had half a tank of 87 octane... but i used all the gas and then started filling up with 91 octane gas
Old Oct 22, 2007 | 08:45 PM
dc2_97teg's Avatar
can anyone help? at this time of night?
Old Oct 22, 2007 | 09:16 PM
what ecu are you using and what timing setting
Old Oct 22, 2007 | 10:26 PM
dc2_97teg's Avatar
well i am running a obd2a p72 ecu... and the time... i don't know i had a shop do my timing...
Old Oct 23, 2007 | 07:45 AM
check your timing, it may be off, also you may have gotten some bad gas.
Old Oct 23, 2007 | 08:46 AM
dc2_97teg's Avatar
What code would my timing trip? My o2 sensors? or my knock sensor?
Old Oct 23, 2007 | 10:22 AM
potentially both if its not set correctly
Old Oct 23, 2007 | 01:51 PM
happynoodleboy's Avatar
* B A N N E D *
No, a code indicating your knock sensor isnt actually indicating knock, its only telling you 2 things. 1. Faulty knock sensor, or 2. Bad wiring.
Old Oct 23, 2007 | 04:37 PM
dc2_97teg's Avatar
Default Re: gsr knock sensor and o2 sensors stays on!!! (happynoodleboy)
ooo phew thats a relief... knowing that i don't have a knock in my motor.... so lets try to crack down on the o2 sensors? would that be faulty wiring or faulty sensors??? and if so does anyone have any idea how they fixed that problem without replacing... trying to save money... if i have to replace.. well then... what other choice do i have
Old Oct 23, 2007 | 05:29 PM
boostedh22lude1's Avatar
u need a new knock sensor
Old Oct 23, 2007 | 05:41 PM
dc2_97teg's Avatar
Default Re: gsr knock sensor and o2 sensors stays on!!! (boostedh22lude1)
alright ill check the wiring first then ill replace the knock sensor... so anyone have any idea about the o2 sensors??
Old Oct 23, 2007 | 06:41 PM
dc2_97teg's Avatar
any help would be great!!
Old Oct 24, 2007 | 07:47 AM
dc2_97teg's Avatar
anyone have any other helpful ideas for my oxygen sensors?
Old Oct 24, 2007 | 11:16 PM
dc2_97teg's Avatar
anyone have any ideas?? still searching and looking for other ideas
Old Nov 1, 2007 | 02:16 AM
maomaniarocks's Avatar
replace o2 sensor. Buy 2 brand new NTK O2 sensor from Summit Racing. Good price.
Old Nov 5, 2007 | 09:17 PM
dc2_97teg's Avatar
Default Re: gsr knock sensor and o2 sensors stays on!!! (maomaniarocks)
i guess that would always work
shin2max
Sep 18, 2008 04:24 PM
maomaniarocks
May 4, 2007 09:33 PM
elmalouno
Jul 26, 2004 10:27 PM
lowexr
Jul 23, 2003 04:58 PM
SteelCityKid
Apr 16, 2002 10:32 AM
