how do i check motor compression if motor if out of the car?
Old Oct 22, 2007 | 06:57 PM
JDM_EK_JOE's Avatar
Default how do i check motor compression if motor if out of the car?
Hey if im looking to buy a motor and want to test the motor out for compression to make sure it isnt beat to **** with low compression. How do i do this?
Old Oct 22, 2007 | 07:01 PM
EGmikeH22's Avatar
* B A N N E D *
jump the starter directly with a battery, then use a compression checker as usual
i don't know what electronics in the starter this will destroy, but it'll tell you how good compression is
Old Oct 22, 2007 | 07:11 PM
Hardedge's Avatar
Still not very accurate readings cause the engine isn't warm. The only thing you can check with the motor removed is consistent compression.
krazeenoy
Nov 11, 2008 06:21 AM
sirguy01
Jul 6, 2006 09:03 PM
JDMEMM
Oct 21, 2002 10:56 PM
