ls vtec
Old Oct 21, 2007 | 03:59 PM
92hatchboi's Avatar
Default ls vtec
i just swapped an lsvtec into my car i have an obd2 wireharness. the car runs fine but the problem that im having is that the tachometer doesnt work and the speedometer was like the tach is suppose to and the battery light is on. anybody has any suggestions and what it could be?
Old Oct 21, 2007 | 04:09 PM
philosofy1's Avatar
Default Re: ls vtec (92hatchboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchboi &raquo;</TD></TR><TR><TD CLASS="quote">i just swapped an lsvtec into my car i have an obd2 wireharness. the car runs fine but the problem that im having is that the tachometer doesnt work and the speedometer was like the tach is suppose to and the battery light is on. anybody has any suggestions and what it could be?</TD></TR></TABLE>
i would make sure the battery terminals are tight, as well as all ground wires.
as for the speedometer, did you connect the vss at the tranny?
Old Oct 21, 2007 | 04:12 PM
92hatchboi's Avatar
Default Re: ls vtec (philosofy1)
yeah the speed sensor is connected. when i rev the car the speedometer acts as if its the tach and moves up and down
Old Oct 21, 2007 | 04:14 PM
philosofy1's Avatar
what year civic is this?
Old Oct 21, 2007 | 04:15 PM
92hatchboi's Avatar
its a 92 eg. i had an ls in there and everything worked fine.
Old Oct 21, 2007 | 04:26 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchboi &raquo;</TD></TR><TR><TD CLASS="quote">its a 92 eg. i had an ls in there and everything worked fine. </TD></TR></TABLE>
are you sure you connected everything right at the distributor?
Old Oct 21, 2007 | 04:27 PM
92hatchboi's Avatar
its an obd 2 distributor it only has one plug. the car starts and runs fine with no problems.
Old Oct 21, 2007 | 04:31 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchboi &raquo;</TD></TR><TR><TD CLASS="quote">its an obd 2 distributor it only has one plug. the car starts and runs fine with no problems. </TD></TR></TABLE>
hmmm...this might be the rot to your problem. someone correct me if i'm wrong but i believe obd1 motors have 2 connectors at the distributor. when you say you are using a obd2 wire harness, do you mean a jumper harness at the ecu, or does that include the motor harness as well?
Old Oct 21, 2007 | 04:36 PM
92hatchboi's Avatar
its an obd2 engine harness. i dont understand how the speedometer signal and the tachometer signal are crossed ( im assuming)
Old Oct 21, 2007 | 04:51 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchboi &raquo;</TD></TR><TR><TD CLASS="quote">its an obd2 engine harness. i dont understand how the speedometer signal and the tachometer signal are crossed ( im assuming)</TD></TR></TABLE>
neither do i, but i do know that the tach works and is wired off of the dist. maybe that has something to do with your problem. sorry i couldn't be much help!
Old Oct 21, 2007 | 04:53 PM
92hatchboi's Avatar
thanks. any advice is helpful. anybody have anyother suggestions
Old Oct 21, 2007 | 04:56 PM
1sickEJ's Avatar
make sure the wiring to your cluster is correct.. and in good conditon.
Old Oct 21, 2007 | 05:00 PM
92hatchboi's Avatar
Default Re: (1sickEJ)
everything worked fine when the ls was in there now i swapped in my project motor and the wires are acting like they are crossed
Old Oct 21, 2007 | 06:44 PM
92hatchboi's Avatar
anybody have a clue about this
Old Oct 21, 2007 | 07:05 PM
mesach0's Avatar
not sure but have you check'd your alt speed sensor fuse.
Old Oct 21, 2007 | 07:26 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchboi &raquo;</TD></TR><TR><TD CLASS="quote">anybody have a clue about this</TD></TR></TABLE>
Yeah. Get OBD1 injectors and a distributor and wire your car properly. I guarantee it'll fix the problem.
Old Oct 21, 2007 | 08:35 PM
Jdm Primer Eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
as for the speedometer, did you connect the vss at the tranny?</TD></TR></TABLE> well i did the same swap on my hatch but i went back to obd 1 and just ran a different wire haeness foe the v-tec
drew_kousk
Jul 11, 2008 03:48 AM
JDMtype Eg6
Apr 26, 2006 11:34 PM
dcfour
May 12, 2005 09:34 PM
roycivic92
10
Jan 21, 2005 03:58 PM
invboost
13
Dec 17, 2003 03:45 PM
