Moonroof stuck in vent open position
Old Oct 21, 2007 | 01:11 PM
eilros's Avatar
Default Moonroof stuck in vent open position
The moonroof slides back and forth just fine and will fully open. Unfortunately when I try to close it, it doesn't fully close and stays in the vent open position. I have cleaned the rails and lubed them. Does anyone have any ideas how to fix this problem?
Old Oct 21, 2007 | 03:55 PM
eilros's Avatar
Default Re: Moonroof stuck in vent open position (eilros)
Here are a couple of pics that show how it's stuck:
Old Oct 21, 2007 | 04:21 PM
beastman@'s Avatar
It's trying to get away from your paint.
Old Oct 21, 2007 | 04:36 PM
bigkvn77's Avatar
Default Re: Moonroof stuck in vent open position (beastman@)
I had the same problem. Got someone toget inside and open it. As they closed it, I hit the back part (the side of the moonroof that is up). I repeated it until the moonroof closed (usually 3- 4 tries). I don't use it that often any more. I know there is a fix for it. Ill look for it and give you a link if I find it. Now after the fix the problem is it opening. I have to give it a gentle persuasion to get it to pop up. But that is way better then stuck open
Old Oct 21, 2007 | 05:24 PM
eilros's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beastman@ &raquo;</TD></TR><TR><TD CLASS="quote">It's trying to get away from your paint. </TD></TR></TABLE>
I hear ya. Actually the paint is decent. It's the clear coat that's shot.
Old Oct 22, 2007 | 08:43 AM
eilros's Avatar
Default Re: Moonroof stuck in vent open position (bigkvn77)
I was able to get it closed using the hand crank. However, whenever I open the moonroof it stays open. Right now my two options are to either not open the moonroof or to hand crank it closed every time I use it. Does anyone have any ideas for a permanent fix? I really want to use the moonroof but it's a PITA to hand crank it closed all the time.
Old Oct 22, 2007 | 04:18 PM
Rainmaker's Avatar
Problem might be gunk in the contacts of the switch. I have to clean mine every 2 or 3 years. Pop the switch out, dismantle it, and then clean/file down the contact points. For some reason that switch gets carbon buildup on it, which makes it not work as well after a while.
Old Oct 28, 2007 | 11:50 AM
eilros's Avatar
Default Re: Moonroof stuck in vent open position (Rainmaker)
I was able to get it to close without any problems. I cleaned the tracks with Q-Tips and sprayed the tracks with silicone. I opened and closed the moonroof 5-6 times and it's been working flawlessly ever since.
Projectjdm4
16
Apr 27, 2008 02:53 PM
vc
Nov 17, 2006 09:27 PM
eg_coupe94
Jul 6, 2004 10:41 PM
dyases
Jan 9, 2003 01:43 PM
airon
13
Feb 21, 2002 11:57 PM
