Fuel Gauge needle Broke =\
Old Oct 20, 2007 | 07:56 PM
Danielh22vtec's Avatar
Default Fuel Gauge needle Broke =\
I was installing some colored guage covors on my 90 hatch and broke the fuel gauge needle off, i was wondering if anyone else had had this problem and knows if i have to get a whole new dash or if there is a way i can just replace the needle.
Old Oct 20, 2007 | 10:23 PM
crxcess's Avatar
Default Re: Fuel Gauge needle Broke =\ (Danielh22vtec)
did just the needle break off or the part inside? either way, you could try and find a automatic cluster cheap and use it for parts. or look for a good deal on a replacement cluster.
Old Oct 20, 2007 | 10:34 PM
denraweb's Avatar
Default Re: Fuel Gauge needle Broke =\ (crxcess)
If just the plastic needle broke off, go to the junkyard a find one on a cluster and pull it off with a fork or special fork style tool. Put it in your pocket and leave...if you broke the metal pin that the needle sits on, you will need to replace the whole gas gauge piece.
Old Jan 10, 2009 | 11:46 PM
hugo_one's Avatar
i just had the same problem all other gauges came out fine but the gass gauge, the metal piece broke off inside so i got another cluster and it did the same thing - any ideas would b great cant keep ordering them
Old Jan 11, 2009 | 12:01 AM
D16SiHatch's Avatar
i would simply suggest not using indiglow gauges and then you wont run into issues with needles breaking off.
Old Jan 11, 2009 | 12:04 AM
miguey310's Avatar
Just buy a new cluster
Old Jan 11, 2009 | 12:12 AM
96accordsir's Avatar
ya i got my si cluster at the junk yard for only 30
Old Jan 11, 2009 | 12:38 AM
~sp33~'s Avatar
EFB055
Glue it back on.
Old Jan 11, 2009 | 08:20 PM
hugo_one's Avatar
its the metal pin inside that broke not the needle itself
SpEcIaLkOuPe
Apr 25, 2009 12:58 PM
spider2465
Jun 8, 2007 06:44 AM
WH0R3nEF9
Mar 28, 2005 06:50 PM
96_GSR
Mar 22, 2003 06:05 AM
