Hydrogen tip
Old Oct 20, 2007 | 06:52 PM
HondaCRXH2O's Avatar
Default Hydrogen tip
Hi all, been working on a Hydrogen boost for my CRX whitouth really thinking it was gonna work but anyway i had increased HP and mpg and the whole thing cost me 50$ to make. So here it is for everyone : Go on youtube and find out how to create Hydrogen whit water ( i wont tell more than that other than it produces oxygen whit a boost of hydrogen ) run it to your intake it will also clean your engine ! (you can use the 12v bat running your car it will work fine !)
Modified by HondaCRXH2O at 8:29 PM 10/20/2007
Old Oct 20, 2007 | 07:58 PM
danmdevries's Avatar
Default Re: Hydrogen tip (HondaCRXH2O)
ummmm......?
Old Oct 20, 2007 | 09:07 PM
ok since its so hard to understand.. The average car engine whit gas only has about a 17% heat efficiently rating. Just 17% goes into turning the wheels and most of the rest is heat lost out the exhaust and radiator. Now boosting the car compresion will help have a more efficient burn and so does Hydrogen whit air, it helps burn all the gas that come in your cylinder on explosion by alot more than you think giving more power at wheels and cleaning the engine since less deposit on piston and all valves. So lets say you have a 135HP engine burning 17% of gas and you give it a better burn up to 50%(all up to your cell setup and how good its working can be from a 0 ~50% whit a cheap budget and if you got money more). you instantly get 33% more power at wheel, you do the maths(it works alot more whit small engines like 1.5 1.6l since they use less air so can take more of the hydrogen air mix produced and it adds alot of torque at low rpm since more hydrogen is pumped in the cylinder)
If you want me to tell how to do it step by step just ask... ill do it when i get the time
Old Oct 20, 2007 | 10:35 PM
1kleenef's Avatar
i sure am wondering would definitily want a step by step
Old Oct 20, 2007 | 10:42 PM
denraweb's Avatar
Default Re: Hydrogen tip (1kleenef)
Yup, waiting on the step by step...
Also can you link the video from youtube as well...
Thanks.
Old Oct 21, 2007 | 02:05 AM
Efbucket's Avatar
Default Re: Hydrogen tip (denraweb)
still waiting,
Old Oct 21, 2007 | 06:33 AM
wiZCo's Avatar
Stouts 'n' Scotch
I call BS. Pretty entertaining though.
Old Oct 21, 2007 | 07:43 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
The concept itself is more then possible. I'd like to see an actual MPG and brake horsepower test before and after to see what it does to the civility of the vehicle as well as the powerband. keep us updated if this is real.
Old Oct 21, 2007 | 06:51 PM
Hi again keep waiting gonna take some time to pull out plans of what i did
Ok lets see if the links work:
1. How to do it ! Its nearly same thing i did !
http://www.youtube.com/watch?v=1NHkbXDuCNg
2.Bonus
http://www.youtube.com/watch?v...earch=
3.Bonus
http://www.youtube.com/watch?v=WpDtGlL6bCI
Old Oct 21, 2007 | 07:00 PM
Tippyman's Avatar
Old Oct 21, 2007 | 07:20 PM
Efbucket's Avatar
Default Re: Hydrogen tip (Tippyman)
Old Oct 21, 2007 | 07:21 PM
Efbucket's Avatar
Old Oct 21, 2007 | 07:37 PM
This is another good video:
Now a complete a standard motorcycle engine fueled whit tap water: not really good results looks like but it works whit water and its a prototype
http://www.youtube.com/watch?v=FW_LQqJk740
Old Oct 21, 2007 | 07:45 PM
Tippyman's Avatar
That's all nice, but I wanna see this **** on your crx.
Old Oct 21, 2007 | 07:57 PM
When ill be done whit everything on how to do it its gonna be show whit my car running it, once im done scanning the plans and doing the tutorials ill tell my friend to come whit hes digi cam that can record
Old Oct 21, 2007 | 08:31 PM
a car fueled whit water alone, done along time ago and still running (Hydrogen from water):
(my opinion is gouvernement dosnt want poeple to use free energie since they get so much more money from gas whit tax)
Old Oct 21, 2007 | 09:31 PM
STREETWERKZ's Avatar
Old Oct 21, 2007 | 09:41 PM
Efbucket's Avatar
Default Re: Hydrogen tip (STREETWERKZ)
[IMG][/IMG]
Old Oct 21, 2007 | 10:24 PM
JKGONZALEZ3's Avatar
this is what i heard about this setup
<U>this is the guy whoi installed it on his car</U>
Its pulling less now.. ;o)
I would like to look at the Ox sensor maybe I can get it to get better MPG..
Do you have any ideas?
Im always up to try new things..
-Pete
you know shooting hydrogen by direct injection would be more practical because hydrogen bonds with the oxygen in the air so your getting allot of water vapor into your combustion chamber and causing allot of unwanted long term damage. plus you might get a slight knock because of the water so you might want to up your octain at the pump from 87 to 91.
Does that car have fuel injection system?
Injection computer sees the extra oxygen and thinks it is running too poor, and adds more gasoline.
So you must modify the oxygen sensor to cheat the computer... I guess your car consumes more gasoline than before...
Am I right?
Old Oct 22, 2007 | 02:16 PM
Default Re: Hydrogen tip (JKGONZALEZ3)
D16 injection and i did cheat whit my O2 sensor by warping it in small carbon dust whit a scring, and since poeple are so interested ill guess the thread gonna close here. Good luck !
Old Oct 22, 2007 | 02:48 PM
SIred91's Avatar
Rainman
You are full of BS.
That is all.
/thread.
Old Oct 22, 2007 | 03:59 PM
ComeOnKip's Avatar
Default Re: Hydrogen tip (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">You are full of BS.
That is all.
/thread.</TD></TR></TABLE>
spoken in painfully honest truth.
ohhh what was i thinking getting my hopes up that we could actually have an interesting non-build thread in here
Old Oct 22, 2007 | 06:42 PM
'90crxSI's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">I call BS. Pretty entertaining though.</TD></TR></TABLE>
I thought so too, but a friend of mine is working on one in his full size blazer, and it really does look promising. Hes got me getting into it too...I'm gonna try it on the rex first to see what it does, and if it works, on my Ram to help the mileage. From the research I've done, it really is possible.... We're currently building the circuit board to control the 'reactors' power right now. Also, it is possible to run the engine completely off of hydrogen! However, I do not yet know what all will be needed to do it, or how much would possibly have to change in the engine to make it safe....
Anyway, I'm giving it a shot!
ilsimsli
Welding / Fabrication
19
Jun 11, 2007 04:20 PM
ilsimsli
Apr 23, 2007 07:50 PM
hondaswaper
Aug 29, 2002 02:25 AM
RH+G
Feb 10, 2002 08:39 AM
Duck Sauce
Nov 9, 2001 06:01 PM
