wiring problems
Well on a semi successfull wire tuck attempt I extended the driver side engine bay harness so I could tuck it in the fender. Everything went well and all the lights work BUT now the horn will not work, and also the brake lights do not light up when pressed. I was wondering if anyone has experience with this? I am sure the 2 are linked together in some way. This is for an 89 crx si. thanks
well I fixed that problem, the fuse was blown......but now the left turn signal works but when i put the right one on the turn signal fuse blows. I dont know why that is happening. I would suppose it is shorting out somewhere?
slvrcivic97
Jul 31, 2003 07:46 AM
