97 Del Sol wont shift into gear when car is on
Old Oct 20, 2007 | 02:29 PM
xboxhaxorz's Avatar
Default 97 Del Sol wont shift into gear when car is on
So i had not driven my car for about 2wks as i was out of town when i returned i tried driving the car would not go into gear i had to push really hard to get it into reverse but would not go back into another gear.
A few dys later i tried again same thing too hard i felt i was gonna break it if i pushed it, so i opened the hood looked around wasted some time while the car was on and went back in and it worked WOW so i drove to a store hung out for about 45mins came back drove home.
A wk later i tried driving same thing wont go into gear, i looked online and couldnt find much, except then i tried shifting when car is off works but when on doesnt work. Also my ebrake has been extremely hard to push down i noticed that before the shifter stopped shifting.
Its a 97 del sol with about 135 miles on it, i bought it from a guy who had a short shifter installed not sure if that matters. Now im stuck and hope to get this fixed.
Any other details need do let me know?
Old Oct 20, 2007 | 03:24 PM
RC000E's Avatar
Default Re: 97 Del Sol wont shift into gear when car is on (xboxhaxorz)
It's either your clutch or your clutch hydraulic system. How does the clutch pedal feel and where does it begin to feel pressure (low to the floor, high up).
Have someone push your clutch pedal and look at the slave cylinder on the lower front of your tranny. As they push the pedal see how much stroke the slave cylinder is providing. If everything is as normal...stroke, fluid level, and pedal feel, then the clutch pressure plate is the issue.
Old Oct 28, 2007 | 11:09 AM
xboxhaxorz's Avatar
Default Re: 97 Del Sol wont shift into gear when car is on (RC000E)
the clutch pedal seems to have pressure towards the bottom, it doesnt really do anything towards the top and it will stay in that position unless i kind of push it in all the way
im gonna get somebody to help me look at the thing you mentioned
Old Oct 28, 2007 | 12:55 PM
PinoyDelSol's Avatar
* B A N N E D *
if you cant get it in reverse the first time, try putting it in 1st gear and than bring it right to reverse! it should go right in.
Old Oct 28, 2007 | 03:19 PM
sc95delsol's Avatar
sounds like you need to either bleed (hydrolic) or adjust (mechinical) you clutch. try that first!!!!!!
Old Oct 28, 2007 | 04:06 PM
stock_honda_coupe's Avatar
Default Re: 97 Del Sol wont shift into gear when car is on (sc95delsol)
You should feel resistance almost right away when you push the clutch in, sounds like the hydralic system is leaking or has air in it.
Old Oct 29, 2007 | 10:35 AM
Projectjdm4's Avatar
i had this problem. I change my slave cylinder. then after that realize it was my clutch took it apart then found out the spring fell out. and replaced it with a exedy stage 1 clutch. it could be one of those 2 problems
Old Oct 29, 2007 | 10:40 AM
nix94delsol's Avatar
Default Re: (Projectjdm4)
how much clutch fluid do you have in it?
Old Oct 31, 2007 | 01:56 PM
xboxhaxorz's Avatar
Default Re: (nix94delsol)
well i didnt have anybody to help me check things, so i towed it to a gas station near my place and they said it is the hydraulic pump leaking and its gonna be $1200 to fix it
would that be correct? cause that sucks for me then
Old Oct 31, 2007 | 02:15 PM
Default Re: (xboxhaxorz)
WTF?!?!?!
Old Oct 31, 2007 | 04:39 PM
You would think gas stations would have enough money as it is. That is outragous, That should be what you would pay for a whole new transmission instaled. not just a hydralic cylinder.
Old Nov 1, 2007 | 10:02 AM
xboxhaxorz's Avatar
Default Re: (stock_honda_coupe)
ya i got a hold of a mechanic thats willing to fix it for the price of an xbox so that tells me its nowhere near the price they are asking
since im getting this replaced is there anything else i should replace as well by that i mean replace the clutch anyways? maybe it will go bad later
Old Nov 1, 2007 | 11:20 AM
boostedh22lude1's Avatar
if your slave is not leaking then its fine, your master is probably worn out, where the f@#k did they get 1200 that the price of a tranny and labor.
Old Nov 1, 2007 | 02:04 PM
vrrodri's Avatar
must be a very special hydraulic cylinder!!
95islegreensol
14
Feb 3, 2018 01:41 PM
ChrisFred96
Jul 28, 2016 12:47 PM
dragonxiong88
13
Mar 25, 2011 04:40 PM
johnnyare
Feb 12, 2010 03:13 AM
pakman2002
Mar 7, 2004 11:34 PM
