Check Engine Light Unplugged?
Old Oct 19, 2007 | 08:38 AM
OMGBBQTEHWTFDOOD's Avatar
Default Check Engine Light Unplugged?
The engine light is supposed to come on for a few seconds when you turn the ignition, right? Mine doesn't. I'm guessing the previous owner either snipped it or broke the bulb or something cause I've never seen it on (he also failed to mention a bunch of other issues with the car)
Is there a way to check what codes it may be throwing without replacing the light? I was thinking one of those bulbs that you use to detect electric currents, but I'm not sure. I do plan on replacing it but I just want to know asap what codes its pulling.
Car is a 1990 Std converted to mpfi, if you're curious.
Old Oct 19, 2007 | 08:58 AM
charlee's Avatar
Default Re: Check Engine Light Unplugged? (OMGBBQTEHWTFDOOD)
if it is an obd1 car then you are supposed to ground out the check engine light wire. pin d4. if its an obd0 just pull the carpet back to expose the computer to see if the LED in the ecu flashes. if it does count how many times it flashes to see if you have a cose. a lot of times people will disconnect the check engine light to mak it seem like there is nothing wrong with the car.
Old Oct 19, 2007 | 09:53 AM
yeah its obd0. I didnt know that there is a led in the ecu with obd0 that helps a lot im going to go check it right now
Old Oct 19, 2007 | 10:09 AM
yeah its throwing code 10 (iat) and 14 (iac) which is from the cheap ram intake on it I'm guessing.
Would these make my idle high? It does idle at like 1300-1400 rpm but its fairly consistent (it doesnt bounce really). My guess is that the previous owner made it idle high so it wouldn't bouce.. Who knows. At least its nothing serious.
Old Oct 19, 2007 | 10:18 AM
Max Kling's Avatar
Intake or intake manifold. Intake has nothing to do with it. And yes those would both cause idle problems.
TeamSumner
Sep 29, 2014 05:14 AM
jakscivic
May 14, 2005 01:49 PM
1991HondaAccord
Jan 20, 2005 10:23 PM
ex_crxer
Apr 6, 2002 07:54 AM
VTECVillain
Jan 6, 2002 11:40 AM
