.020 Over...Pistons?
Old Oct 18, 2007 | 05:33 PM
D-SOHC 05's Avatar
Default .020 Over...Pistons?
Sorry if the topic title is confusing but I wanted this thread to get some attention . I am having my d16 block bored .020 over to get rid of a bit of a lip that has occured in the cylinder walls for whatever reason which at this point is unclear. So, I am wondering if going .020 over stock is enough to constitute getting .020 over pistons (75.5mm) or just getting .020 oversized rings? I can imagine pros and cons for both applications but I want to know what the pros here think before I get pistons and rings. Thanks guys.
Old Oct 18, 2007 | 05:50 PM
sik96teg's Avatar
Default Re: .020 Over...Pistons? (D-SOHC 05)
that seems like a pretty good questions im no motor guru but to me it seems that due to the piston to cylinder wall clearance is going to be greater and the piston rings would have to be sealing that .5mm more of area than what they are intended to cover because more of the ring would be protruding further away from the piston since the piston is 75mm and the rings are for 75.5 pistons so it seems to me that the rings may prematurely fail. may also run into further ruining your cylinder walls jus due to that greater area of clearance between the piston and the cylinder wall. thats just how i see it i may be wrong.
Old Oct 18, 2007 | 09:29 PM
McDonagh's Avatar
Ask your machine shop for advice, they'll know what to do
Old Oct 19, 2007 | 06:04 AM
D-SOHC 05's Avatar
Default Re: .020 Over...Pistons? (sik96teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sik96teg &raquo;</TD></TR><TR><TD CLASS="quote">that seems like a pretty good questions im no motor guru but to me it seems that due to the piston to cylinder wall clearance is going to be greater and the piston rings would have to be sealing that .5mm more of area than what they are intended to cover because more of the ring would be protruding further away from the piston since the piston is 75mm and the rings are for 75.5 pistons so it seems to me that the rings may prematurely fail. may also run into further ruining your cylinder walls jus due to that greater area of clearance between the piston and the cylinder wall. thats just how i see it i may be wrong.</TD></TR></TABLE>
Thats kinda how I felt too so I aksed around and talked to some guys who have built some monster engines for some chevys and fords and they all said that anything below .060 over is totaly good with just oversized rings. This may indeed be the case for fords and chevys but hondas may be a different story. I will ask the guys at the speed shop when I pick up the block in a week or so, but in the mean time if anyone has more info shoot it my way. Thanks
Old Oct 19, 2007 | 05:23 PM
D-SOHC 05's Avatar
Still in limbo on this one.......research?
Old Oct 20, 2007 | 05:26 AM
NJIN BUILDR's Avatar
You will need the same oversize pistons for the bore size.So a +.020" bore requires a +.020" piston and rings.You should have the pistons before the block is finish honed to get the piston to wall clearance correct.
Old Oct 21, 2007 | 04:18 PM
Jim Truett's Avatar
Default Re: .020 Over...Pistons? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">You will need the same oversize pistons for the bore size.So a +.020" bore requires a +.020" piston and rings.You should have the pistons before the block is finish honed to get the piston to wall clearance correct.</TD></TR></TABLE>
Exactly.
Unless you want that motor to come apart in short order, get the pistons and rings. Ignore any advice you have received previously.
Old Oct 21, 2007 | 07:46 PM
sauceja's Avatar
Default Re: .020 Over...Pistons? (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly.
Unless you want that motor to come apart in short order, get the pistons and rings. Ignore any advice you have received previously.</TD></TR></TABLE>
Especially coming from anyone who owns a domestice car/motor.
Old Oct 22, 2007 | 11:15 AM
D-SOHC 05's Avatar
Thanks for the help guys.
Ep3tat98
K Series
Feb 3, 2016 10:20 PM
zenon8890
Feb 5, 2009 06:01 PM
5_Lug_B
Aug 5, 2007 09:26 PM
da_rimrocka
Nov 30, 2005 12:14 PM
turbociv
16
Jul 21, 2003 01:13 PM
