Drag Turbo Kit
what do you all think about the drag turb kit on a b18c in a 96 civic coupe dx. compared to other turbo kits, how is the reliability, dependability, life, and performance of it. ive heard they are really good. it would be 8 or 9 psi. what is the average install time and what kind of gain am i looking at. also it would have the 3" down pipe? and suggestions or comments
yes their good kits..just use search you'll find that there are better stuff out there cheaper.(hit build your own kit) if the motor is bone stock the maybe arond 190whp? something like that....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sickEJ »</TD></TR><TR><TD CLASS="quote">good rule of thumb is 10 hp for every 1 psi you boost.. id go with a kit from full race.. get your moneys worth</TD></TR></TABLE>
yeah, full-race is quality, but expensive as hell. really not necessary at this point for the OP.
Good company though
What stage is the kit? Don't they come in different stages, hence, different specs?
Good company though
with a stock clean, lower mileage b18c in a bone stock 96 Civic coupe dx with obd 1. i would be at 270 hp and the whp would be 240ish with a drag turbo kit at 9 psi w/3" down pipe? daily driven is 8 or 9 ok espec. since im not gonna get on it all the time? i mean i know forced induction can put wear on your motor overtime espec if you dont have the air/fuel ratio balanced, but the fmu will take care of that part. if you watch how you drive is 8 or 9 good?
The horsepower difference doesn't really mean too much...it does make a difference (don't get me wrong), but the real difference is in the amount of torque you'll be making.
I'll be going with the Full-Race kit when the time comes...I've heard nothing but good things, even though it is a tad bit more expensive
EDIT: But if you're looking specifically at the DRAG kit, then yeah, those are good too
do you know how much torque with that setup? i dont think there is going to by too much tuning for now. so that is why i just wanted to play it safe, but still want boost. so with 8 or 9 psi about how much whp am i looking at and torque? also is 9 psi safe or is there a safer boost without tuning for now
1JDMDOMINICAN
Apr 19, 2006 10:27 PM
