IACV help??? gsr motor in 96 hatch
Old Oct 18, 2007 | 09:41 AM
BoostnEK6206's Avatar
Default IACV help??? gsr motor in 96 hatch
i was throwing a IAT code only and now that i fixed that with a new sensor it is thrown the IACV code 14??????
Old Oct 18, 2007 | 10:39 AM
97Ej6mike's Avatar
well, are you experiencing an erratic idle, or a loping one? Try reseting the ECU again, see if it goes away.
Old Oct 18, 2007 | 10:56 AM
i.'s Avatar
i.
check your TPS and idle settings. do you have access to a scan tool, like the snapon one? would make life way easier.
TPS setting should be 10% with the throttle closed, idle should be 700-800. little higher if you got a canadian motor.
additionally, code 14 is not IACv. it is idle air system malfunction. could be caused by a bad iacv, but also a bunch of other things.
Old Oct 18, 2007 | 01:38 PM
Default Re: (i.)
it has a good idle at like 900 jus on start up it will drop down for a sec then idles fine. and when its idling it wont throw the code but when u give it gas it will
Old Oct 18, 2007 | 06:09 PM
imptricer's Avatar
Default Re: (BoostnEK6206)
up any ideas i think the tps is ouf of adjustment i glanced at it looks to one side any other ideas
Old Oct 19, 2007 | 11:23 AM
bump......
poppypizza
May 1, 2008 07:47 PM
c0nspire
Feb 23, 2006 02:09 PM
saucyhatch
Feb 11, 2004 07:27 AM
Glocked1
12
Jan 22, 2004 08:13 PM
