Best way to tune under/over steer...
Old Jun 20, 2002 | 03:13 PM
Jordan_4WS's Avatar
New User
Default Best way to tune under/over steer...
I am thinking of doing it the following ways... Which are the better ways to do it, and why?
1) Tires - Wider tires up front, narrower in back. I am thinking this isnt a great method, since tires affect other things before just handling and I think it might be better to stick to wider tires on all 4 corners
2) Sway bars - manipulating sway bar combination to manipulate over/understeer
3) Strut adjustments (stiffness)
4) messing with camber
I know a good suspension setup is a mixture of all of these, but I am just wondering what are the pro's and con's to using each method to tune suspension.
Thanks, Jordan
Old Jun 20, 2002 | 04:10 PM
EH2DX's Avatar
Default Re: Best way to tune under/over steer... (Jordan_4WS)
you're right on track jordan. just set it up to go well with your driving style.
try different settings until you find one you like the best.
btw, wider tires on all 4 corners are better if you ask me. i'm usinig 225/45/16 and i'm really happy with them. i'm also using TEIN coilover/shock combo, eibach tower bars, and shopping for lower tie bars. i'll most likely get tanabe ones because i had them before i know they work great.
also getting rid of some weight will have some effect on handling as well, c/f hood, gutting the rear and trunk, etc...
Old Jun 20, 2002 | 05:24 PM
Steppin Razor's Avatar
New User
Default Re: Best way to tune under/over steer... (BB1)
1)swaybars. Easiest, safest, best way to get rid of understeer.
2)springs and shocks.
3)tire pressures. Messing with your tire pressures is a good way to tune handling characteristics, and much cheaper than using different tire sizes.
Old Jun 21, 2002 | 12:32 PM
luderacer's Avatar
"eibach tower bars, "
Are these the strut bars? I never knew eibach made some for preludes. Just curious.
Thanks
Old Jun 21, 2002 | 08:16 PM
Buckkaaaa!!'s Avatar
New User
Default Re: Best way to tune under/over steer... (luderacer22)
hmmm i don't know.... for understeer sometimes i think adding some weight in the back actually helps some....
Old Jun 22, 2002 | 11:05 AM
LudeBehavior's Avatar
New User
Default Re: Best way to tune under/over steer... (preludeboy)
I say gor for the sway bars they are the quickest and easiest to feel the difference in. Wider tires are great as well for putting the power down and hold the corners well.. if ya do go for wider tires 225 on stock rims are good..back tires sometimes catch on stuff and break...had it happen it sucks...
7rrivera7
Suspension & Brakes
14
Apr 23, 2013 10:04 AM
E-Money
Feb 10, 2007 10:38 PM
EKcivic1230
May 20, 2005 08:40 PM
Ziatic
12
May 11, 2004 09:58 AM
12 oz.
23
Apr 17, 2002 04:48 PM
