Which Suspension component makes the most noticable difference!!?!?!??!?!?!?!?
Well right now I'm riding on H&Rs and illuminas but I'm looking to spend a bit more on my suspension. My question is which component will make the biggest difference in terms of front upper strut bar, front lower strut, rear strut bars, tie bars etc? if possible please let me know what brands you guys are using.
thanks
thanks
Re: Which Suspension component makes the most noticable difference!!?!?!??!?!?!?!? (Ziatic)
sway bars are the best bang for the buck
grund control and cusco make some good ones
I would say go in this order:
springs/shocks or coilovers
wheels/tires (HUGE difference depending on quality of tires)
sway bars
all the bushings
strut bars
traction rods
tie bars
sway bars
all the bushings
strut bars
traction rods
tie bars
Re: Which Suspension component makes the most noticable difference!!?!?!??!?!?!?!? (h22John)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22John »</TD></TR><TR><TD CLASS="quote">tires, by far. using azenis here....................John</TD></TR></TABLE>
hope you have some tires for winter john.
I would try and get some kind of cheap oem honda
swaybar setup. I have a eg6 21mm front and gsr 14mm rear.
Re: (mister2racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mister2racer »</TD></TR><TR><TD CLASS="quote">I would say go in this order:
sway bars
all the bushings
strut bars
traction rods
tie bars</TD></TR></TABLE>
Energy Suspension's bushing kit makes a huge difference
sway bars
all the bushings
strut bars
traction rods
Re: (SC0TT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SC0TT »</TD></TR><TR><TD CLASS="quote">Energy Suspension's bushing kit makes a huge difference </TD></TR></TABLE>
Hell, if you're riding around on 10-12 year old stocks, even new OEM rubber ones will feel a hundred times better.
Re: Which Suspension component makes the most noticable difference!!?!?!??!?!?!?!? (elwood)
[QUOTE=elwood]
QUOTE]Of course, but thats what the em1 is for(oh wait it's on azenis too)muhahaha, for real I have winter treads for both cars when needed. def need winter tires if you run a truly high performance tire...............John
the es master bushing kit is a great bang for yo buck mod. it really makes your car more responsive and nimble. mine is so fun to toss around.
if you're fighting understeer, a rear anti-sway bar is what you need. comptech makes a great one, and the ITR bar works well also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ziatic »</TD></TR><TR><TD CLASS="quote">My question is which component will make the biggest difference in terms of front upper strut bar, front lower strut, rear strut bars, tie bars etc? if possible please let me know what brands you guys are using.
thanks</TD></TR></TABLE>
Don't really worry about those. They help but not as much as you'd hope. Invest in some grippy tires. Tires play a key factor in grip for obvious reasons. Then look into anti-sway bars. For my EJ8, I use the stock front piece (22mm) and run a Progress 22mm in the rear. Very fun setup. The rear end can and will step out (and it has), but it's fairly catchable. My NT-450s are definitely holding the grip level back, though.
Re: (Ziatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ziatic »</TD></TR><TR><TD CLASS="quote">thanks for the tips guys
i have tires covered for the time being....not the best set but they're ok(kumho 712s)
Then get some sways.
