Strange Smell when accelerating..
Old Oct 17, 2007 | 05:35 PM
Dicorp's Avatar
Default Strange Smell when accelerating..
My car has a weird smell when i give it full throttle. the muffler needs replacing and there might be a small oil leak from the valve cover gasket. which one is more likely to cause the smell?
Old Oct 17, 2007 | 05:47 PM
Acidcrakker's Avatar
Default Re: Strange Smell when accelerating.. (Dicorp)
Well what does it smell like burning oil, or exhaust fumes. You should fix both problems right away.
Old Oct 17, 2007 | 05:50 PM
Dicorp's Avatar
Default Re: Strange Smell when accelerating.. (Acidcrakker)
the problem is, im not sure...maybe the combination of the 2. muffler im not worried about, yet. the oil is worrying me. how hard is it to change the valve cover gasket?
Old Oct 17, 2007 | 05:55 PM
Its a cake Job. Any noob can do it, Im a noob and I can do it.
1. Autozone and buy new valve cover gasket like 25 bucks
2. Let car cool off
3. Remove all 4 bolts on valve cover, PVC valve, ground wire, and anything else connected to top of cover. NOt in that order
4. Take off, remove old gasket, careful not to let any of the old gasket break off and into the head.
5. Apply new gasket.
6. Repeat step three backwards.
25 mins max
YOu might even want to consider painting the valve cover while its off.
Old Oct 17, 2007 | 06:00 PM
Dicorp's Avatar
ok, sounds good, will do this weekend
Old Oct 17, 2007 | 07:12 PM
shadow29485's Avatar
Old Oct 18, 2007 | 08:31 AM
92bluepreludeSi's Avatar
Default Re: Strange Smell when accelerating.. (shadow29485)
well if it only smells bad when you give it full throttle it would be the smell of the clutch burning from it slipping.
Old Oct 18, 2007 | 09:07 AM
Dicorp's Avatar
Default Re: Strange Smell when accelerating.. (92bluepreludeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92bluepreludeSi &raquo;</TD></TR><TR><TD CLASS="quote">well if it only smells bad when you give it full throttle it would be the smell of the clutch burning from it slipping.</TD></TR></TABLE>
thats what i was thinking initially, cause oil would have a constant smell. for example this morning when i was driving normally, i didnt smell anything. last night when gunning it, i could smell it
Old Oct 18, 2007 | 10:01 AM
So that means you now have three problems to take care of.
Old Oct 18, 2007 | 11:21 AM
jdmbreed's Avatar
sometimes when i give it full throttle i get overly excited and fart could that be it???
1. i would check for leaks (oil burning touching header or burning off engine would be a constant smell though)
2. clutch
3. did u happen to have had ur car tuned recently maybe A/F ratio off alittle ???
hope u get this fixed soon let us know details when you find something else out
Old Oct 18, 2007 | 02:18 PM
Default Re: Strange Smell when accelerating.. (jdmbreed)
well... if its not your clutch it could be the muffler bearing.
Old Oct 18, 2007 | 02:27 PM
dagle's Avatar
are your AC vents open? shut them and see if the smell is still there... what kind of smell is it btw? sweet? savory? fish(coolant!)? poopy/farty(you or sulfur from something i forgot)
Yuta
Dec 12, 2015 05:27 PM
rovafa2002
Jul 2, 2013 07:50 AM
bka112
Jun 21, 2007 08:17 PM
Shaguar47
May 28, 2007 08:47 AM
Qwikrex
Nov 18, 2002 02:13 PM
