how do you clean the iavc and that other thing please help ( idle problem_)!!!!!!!!!!!!!!!!!!!!!!!!
im having idling problems and i read that you should clean them out and im wondering how you do that i might go buy some new ones but im not even sure what application to get i have a b16 so im thinking like an ls one or something but i dont know what kinna carb or intake manni i have all i know is my **** is odb0 thats it my map sensor could be bad too but i dont know
Search.
PS: It's called IACV ("Idle Air Control Valve").
And it's not a very fun thing to take off. It requires a lot pulling, twisting, and manliness.
I need to make a how to thread for this.
1) Warm car
2) Shut off car
3) Remove air intake from throttle body
4) Start car
5) Spray carburetor cleaner in the ~10:30 position hole in the throttle body. (This feeds the IACV)
6) Car will stall
7) Let sit for a minute
8) Repeat from step 4 until satisfied
9) Reattach air intake
10) Reset ECU
1) Warm car
2) Shut off car
4) Start car
6) Car will stall
10) Reset ECU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR »</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...=1174</TD></TR></TABLE>
The problem with this method is that the solenoid plunger is not moving and the cleaner is not drawn through the IACV.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">I need to make a how to thread for this.
1) Warm car
2) Shut off car
4) Start car
6) Car will stall
10) Reset ECU</TD></TR></TABLE>
I'm going to give this a try in the future. A lot less work and it sounds like it will get better results.
1) Warm car
2) Shut off car
4) Start car
6) Car will stall
