my turbo is messing with my stock d15b7 engine!!! help please!!!
Old Oct 16, 2007 | 05:50 PM
rjmancia's Avatar
Default my turbo is messing with my stock d15b7 engine!!! help please!!!
hey guys i need alot of help with my turbo setup! i have a used t3/t4 garrett turbo with no shaft play at all and i dropped it in my stock d15b7 engine and it is intercooled, have a BEGI FMU which is one of the best, have greddy piping, greddy type-rs blow off valve, b&m fuel pressure regulator and everthing else is stock. The problems are that it cuts off my fuel when i boost 3 psi or higher in 4th or 5th gear and also it smokes in between manifold and turbo which is wierd and its white smoke someone please help!!!!!
Old Oct 17, 2007 | 09:19 AM
sleepgsr's Avatar
Default Re: my turbo is messing with my stock d15b7 engine!!! help please!!! (rjmancia)
Are you using a missing link?
Old Oct 17, 2007 | 10:17 AM
sohczcturbo's Avatar
Default Re: my turbo is messing with my stock d15b7 engine!!! help please!!! (sleepgsr)
ummm, running a fmu and a adj. fuel pressure reg. together? I haven't heard of this setup. any cel's? what are you doing to bypass the map sensor?
GaVO311
Nov 7, 2006 08:39 AM
JforJonathan
Apr 23, 2005 03:10 PM
-slow ej-
Mar 24, 2005 06:30 PM
g2_boosted
Sep 28, 2002 06:32 PM
MugenVtek4
Dec 13, 2001 07:52 PM
