Need Help on running turbo
sup dudes,
my friend gave me a 12g turbo with a bov and ic along with all the plumbing, do i need an fcu/fmu to run the turbo at only 6psi, he said that or a turbo fuel regulator and pump or something like that. i wanna run a 12g for autocross reasons. ay help is greatly appreciated.
Probably recommend you learn a bit more about these snails before you actually put one on and take the risk of tearing up your engine. I've never heard of a FCU, an FMU would probably be helpful, but you're going to have to do some research to find out what setup works best for you. Fuel management is probably one of the biggest if not the biggest issue regarding forced induction, so it's best if you get a really good grasp of how they interact. Just my 2 cents, also use the search feature, many, many good topics have been covered at least 5 times a piece
ya like i said, fuel management is my biggest concern, but to run 6psi do i need an fmu or can i use a turbo fuel pressure regulator and hi flo pump? or can the stock units be able to keep u with the 6psi?
sparq
Dec 18, 2002 01:46 PM
DUCK COMMANDER
Jun 17, 2002 04:00 PM
