why would a wastegate just stop working and not opening up???
Quick question for you guys? I have noticed that my wastegate is no opening up for some odd reason and I was messing with the boost controller and thats not it.
timing and vaccum hoses are prefect. So why would a wastegate just stop working?
SOHC TURBO
on 10 psi
tial 38mm wastegate spring at 7psi
SOHC TURBO
on 10 psi
Is it drawing vacuum on the top port of the waste gate? Sometimes the rubber can rip and cause problems or a set screw can possibly back out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL »</TD></TR><TR><TD CLASS="quote">you send it to me and i tell you why
race gas on a pump valve?
taking boost reference off the manifold?
Sounds a bit more like THIS reason here. But details from The OP are needed..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">
Sounds a bit more like THIS reason here. But details from The OP are needed..</TD></TR></TABLE>
If he's using race gas for 10psi of boost, he's got a turbo bigger than my spare tire
I'd recommend you take your WG off and disassemble (unless you aren't 'handy'). It could be corroded or in need of service.
