wrong ecu?
Old Oct 15, 2007 | 08:38 PM
Z you later's Avatar
Default wrong ecu?
drive a 00 civic with gsr swap and p28 skunk chipped ecu. The v-tec in 1st through 3rd is almost 5200 each time but once I go to 4th it change to like 6500 and then when it hit v-tec after a little bit it will bog out so is it the ecu? and also do gsr's have dual v-tec and if so I dont notice it at all?
Old Oct 15, 2007 | 08:40 PM
Hybrid_Ej188's Avatar
its mostly the chip its set at different vtec points
Old Oct 16, 2007 | 11:00 AM
Default Re: (Hybrid_Ej188)
so what can I do?
Old Oct 16, 2007 | 11:07 AM
slo_hatch's Avatar
Default Re: wrong ecu? (Z you later)
yeah the p28 is from a d16z6 or d16y8. its not for a gsr....it might just be where it is chipped. but if it was a virgin ecu, then it would not run the right way. so try to go to a junkyard and get one from a gsr or you might have to buy one from ebay or the marketplace. also only some jdm motors have 2 stage vtec. so if yours is usdm: then no. hope that helps you out.
Old Oct 16, 2007 | 11:08 AM
ek4_b16a's Avatar
Default Re: (Z you later)
just get the right ecu...you really don't need to get a chipped ecu...just get an obd2 gsr ecu...and it'll be fine...less troubles...better gas mileage...
Old Oct 16, 2007 | 11:12 AM
Default Re: (ek4_b16a)
just what I was wondering thanks! also do I need a conversion harness?
Old Oct 16, 2007 | 05:55 PM
slo_hatch's Avatar
no....conversion harnesses are only for going from obd-2 to obd-1 or vice versa. swapping obd-2 for obd-2 is just plug and play.
Old Oct 22, 2007 | 07:47 AM
Default Re: (slo_hatch)
I got a p72 obd II ecu and it does not plug in and play?
Old Oct 22, 2007 | 08:05 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_hatch &raquo;</TD></TR><TR><TD CLASS="quote"> swapping obd-2 for obd-2 is just plug and play. </TD></TR></TABLE>
When its OBD2A and OBD2B they are not plug and play.
mpls
Feb 2, 2009 01:31 PM
RiceOrRocket
Aug 28, 2007 09:13 PM
808State
Jun 21, 2005 08:08 AM
streetlvlhatch
Mar 17, 2004 05:50 PM
NatedoggAZ
Jul 31, 2003 05:01 AM
