oil stick blowing out
Old Oct 15, 2007 | 06:39 PM
pauley_lsvtec's Avatar
Default oil stick blowing out
ok i have a ls vtec makes 172 whp at 8900rpm and the other day im flogging my car like i usually do and it started to smoke inside the car so i pull over and shut it down and find to my suprise oil every where in my engine bay. when i looked down i noticed that my dip stick was out of its hole im assuming that this is do to excessive crank case pressure it burns no oil and it seems to have a little combustion gasses in the oil it self. pcv is new and pcv system is stock so i guess my question is will a catch can eliminate this problem or should i slap the **** out of my engine builder. i have also noticed that i have been since beating on my car tring to make it happen again and its been good. thanks in advance for any help!!!!!
Old Oct 15, 2007 | 06:45 PM
b16a3delsol's Avatar
Default Re: oil stick blowing out (pauley_lsvtec)
Mine did that on my b16 swap but it was because the dipstick was a piece. I actually put one layer of black electrical tape around the part that went into the tube to make it a bit more snug and it hasnt came out since.
Old Oct 15, 2007 | 06:47 PM
forcefedferio's Avatar
you should deffinetely have a catch can anyway.....and your dipstick blowing out of the tube is deffinetely not a good thing
Short Story:
1991 Eagle Talon TSI AWD, my friends car.....18 psi and no fuel upgrades, we couldnt figure out why the car wouldnt run after it randomly shut down on him one night...while cranking the car the dipstick shot out of the tube with enough force to dent the heater duct in his garage, upon engine teardown cylinder #3 had a finger sized hole in it and cylinder #1 fared only slightly better.
hopefully yours doesnt turn out the same way.
Old Oct 16, 2007 | 08:34 AM
Default Re: oil stick blowing out (forcefedferio)
the car runs great and has all the fuel up grades and a full tune so i dont think there could be a hole in the piston but i think i will get a catch can or at least make one so i can be re assured that its ok also it hasent happened since and this was about a week ago. i am also wondering is there some adapter where i can get rid of the black box and eliminate the pcv valve totaly or do i have to run my catch can in line with the pcv and black box still attached. thanks for the help
Old Oct 16, 2007 | 09:41 AM
pdiggitydogg's Avatar
Are your pcv lines run properly? Are the hoses clean?
If you run a catch can, block off the hole on the back of the block where the box was - Advance Auto part # 555104 (Dorman 34.3mm plug) and run fittings ala endyn
Old Oct 16, 2007 | 09:58 AM
C_R_X_'s Avatar
jb weld it
Old Oct 16, 2007 | 10:03 AM
yoffer's Avatar
Banned
Default Re: oil stick blowing out (C_R_X_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X_ &raquo;</TD></TR><TR><TD CLASS="quote">jb weld it </TD></TR></TABLE>
Even if this is a joke, your an idiot for posting this.
Old Oct 16, 2007 | 10:29 AM
drSquish's Avatar
Default Re: oil stick blowing out (yoffer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer &raquo;</TD></TR><TR><TD CLASS="quote">
Even if this is a joke, your an idiot for posting this.</TD></TR></TABLE>
good job. jbweld that mug to the wall
Old Oct 16, 2007 | 06:38 PM
Default Re: oil stick blowing out (drSquish)
thanks for the advice that part number is going to come in handy ill get on top of getting a catch can i noticed that there are some that are like $30 and some that are like $150 so is there a big diffrience or is the one for $150 just "baller status" again thanks for all the info.
carbonemt
Apr 19, 2011 10:03 AM
Lordofdark176
11
Feb 3, 2008 08:09 PM
Kaspk
Dec 11, 2006 10:02 AM
ringgold
Sep 17, 2006 10:51 AM
00IntegraLSO-town
Feb 16, 2006 07:30 PM
