Looking to slam my 00' Si....
Old Oct 15, 2007 | 05:53 PM
warriorti22's Avatar
Default Looking to slam my 00' Si....
So i was talking to my local shop and they directed me away from simply putting some lowering springs on, as they saif it will destroy the stock shock. I was wondering if anybody could input on this, i wanna know if this is really a concern, or wether they are trying to make some more money off me. I was looking at the Tein S-type lowering spring which says it will lower around 1.5 inches. I am running stock wheels if this makes a difference.
thanks for any and all help!
Old Oct 15, 2007 | 06:09 PM
BlueIntegraBoy's Avatar
Default Re: Looking to slam my 00' Si.... (warriorti22)
If you stick with stock struts, they will blow fast. Get aftermarket struts to accomodate the springs.
If you want to spend a little more, get full coilovers with adjustable dampening. This will allow you to adjust the height of your ride so it's not too low or too high.
Old Oct 15, 2007 | 06:12 PM
posHonda's Avatar
I know a few people whove dropped their cars past 1.5" and years later theyre stock struts are still holding up.
That might not be the case for you though. Grab some shocks.
Old Oct 15, 2007 | 06:24 PM
stock_honda_coupe's Avatar
Default Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">I know a few people whove dropped their cars past 1.5" and years later theyre stock struts are still holding up.
That might not be the case for you though. Grab some shocks.</TD></TR></TABLE>
This is true, but if they are at all close to going, they'll blow right away. You'll get a better ride with quality aftermarket struts anyways.
Old Oct 15, 2007 | 06:55 PM
forcefedferio's Avatar
Default Re: (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe &raquo;</TD></TR><TR><TD CLASS="quote">
This is true, but if they are at all close to going, they'll blow right away. You'll get a better ride with quality aftermarket struts anyways.</TD></TR></TABLE>
100% true, if you don't want a stiff coilover ride but want a nice drop get those S-techs or some H&R springs with some tokico blues or gr-2s....or if you want a little nicer strut with some adjustability the AGX's are good as well and on the affordable side.
Old Oct 16, 2007 | 05:00 PM
Default Re: (forcefedferio)
alright, i think ill have to weigh out my priorities now!
im tryin to turbo, but i am torn, as i go to college in a year and i need to save money
Old Oct 16, 2007 | 05:15 PM
spray_bombed's Avatar
my hx is dropped 1.75 front and 1.5 back on h&r springs on a fully stock suspension for about 4 months now with no problems...but its only been 4 months
Old Oct 16, 2007 | 05:19 PM
kay_animation's Avatar
Default Re: (spray_bombed)
Depending on how low you wanna go I'd go with something that is bottom adjustable so that the shock travel does not beat the shock to hell. Of the top of my head, ksport, omni, and all those shocks repainted under hella other names make these. Old ksport shocks blow though so stick with at least the new version of their shock.
But all in all I'd try not to go that low if possible. You'll just scrape everything under your car, exhaust, header, oil pan, etc and end up beating your car slowly. But if you must, take it easy and stay super alert when daily driving
Old Oct 16, 2007 | 05:20 PM
Default Re: (kay_animation)
BTW, stock wheels = 14s You'll have to lower the car a lot to make 14s look slammed and you'll kill your clearance high so look out for road transitions and man holes
Old Oct 16, 2007 | 06:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kay_animation &raquo;</TD></TR><TR><TD CLASS="quote">BTW, stock wheels = 14s You'll have to lower the car a lot to make 14s look slammed and you'll kill your clearance high so look out for road transitions and man holes </TD></TR></TABLE>
just a note his car is an EM1 SI....with 15" wheels.
Old Oct 17, 2007 | 08:09 AM
White Smoke's Avatar
i my honda
Global Mod
The Si shocks are stouter then, ex or dx for example. Also the Si's came from the factory about 1" lower then the ex or dx. If you are only going for a slight drop of 1.5" or so then the stock Si shocks will do you just fine for a good amt of time. I went 40k or a set with sportlines.
JDMEK9R
Dec 18, 2007 03:17 PM
Tutu
Suspension & Brakes
Jul 18, 2005 08:12 PM
EKB18BPR3
Mar 6, 2005 08:01 PM
hondasport2000
54
Mar 15, 2004 08:27 AM
BeauL
Oct 29, 2003 04:33 AM
