How hot does the turbine housing get? What about the DP?
Old Jun 20, 2002 | 10:05 AM
DigitalFusion's Avatar
Default How hot does the turbine housing get? What about the DP?
There are some high-temp paints for like 1500, and i think there is even 1800 (its in an old archive post I bookmarked). Would paint hold up on the turbine? Anyone tried it?
Old Jun 20, 2002 | 10:06 AM
dustin's Avatar
Default Re: How hot does the turbine housing get? What about the DP? (CustomCockpits)
EGTs usually peak at 850C. So the turbine housing is going to be cooler than that.
Why would you want to paint the turbine housing anyways?
Old Jun 20, 2002 | 11:11 AM
filetofit
Guest
Posts: n/a
Hot enough to burn the **** out of your arm if you brush against it while dicking around with your charge pipe clamps.
Old Jun 20, 2002 | 11:15 AM
Etylorcen's Avatar
Default Re: How hot does the turbine housing get? What about the DP? (filetofit)
LOL Lesson to learn: Dont dick around with **** when its still hot hehe.
Old Jun 20, 2002 | 11:16 AM
CovertFI's Avatar
Default Re: How hot does the turbine housing get? What about the DP? (dustin)
before
after
i used the 1500 degree paint like you were aksing. and it still looks good.
Old Jun 20, 2002 | 11:30 AM
technine's Avatar
Default Re: How hot does the turbine housing get? What about the DP? (CovertFI)
Looks good, I was thinking about doing this, now I am.
Old Jun 20, 2002 | 11:36 AM
dustin's Avatar
Default Re: How hot does the turbine housing get? What about the DP? (technine)
hehe, I don't think it will last man But it does look nice.
Old Jun 20, 2002 | 11:47 AM
CovertFI's Avatar
i know what you are saying. it will probably need to be done every year. hell it only cost like 3 bucks for the can.
Old Jun 20, 2002 | 05:31 PM
what makes it not last?
Old Jun 21, 2002 | 02:22 PM
marklamond's Avatar
I did my manifold, exhaust housing and DP with some high temperature enamel stuff (brush on) and put on a few coats. 6000 miles later it still looks good, though it ain't going to last forever.
Old Jun 21, 2002 | 02:40 PM
PrecisionH23a's Avatar
Default Re: How hot does the turbine housing get? What about the DP? (marklamond)
i painted my dp with the 1800 high temp black paint... it ended up turning a white/creamish color, good thing i had heat wrap over it to hide the ugly color it turned.
Old Jun 21, 2002 | 03:55 PM
porch's Avatar
New User
Default Re: How hot does the turbine housing get? What about the DP? (GudeH23a)
http://www.hpcoatings.com/exhaust_coatings.htm
Maybe more than you want to spend, but worth it if you do. :D
Old Jun 21, 2002 | 04:16 PM
FBP Si 2000's Avatar
Is that a EGT probe I see? I want to do the same...
[Modified by FBP Si 2000, 5:17 PM 6/21/2002]
Old Jun 21, 2002 | 04:42 PM
Default Re: How hot does the turbine housing get? What about the DP? (porch)
anyone here have this done? how much is it on average for the manifold?
Old Jun 21, 2002 | 04:43 PM
DeeJay's Avatar
New User
Default Re: How hot does the turbine housing get? What about the DP? (FBP Si 2000)
That's not a good place for it. It should be tapped through the Dp flange where a internal wastegate would go, there you are getting your EGT before the turbo steals some heat.
Old Jun 21, 2002 | 08:27 PM
Default Re: How hot does the turbine housing get? What about the DP? (DeeJay)
i did not want to put the probe before the turbo, ive heard of the probe breaking off before... and well a probe going through the fins of a turbo just doesnt sound too appealing to me...
ESP.net
Paint and Body
Oct 21, 2008 07:35 PM
platinum00
Mar 29, 2004 05:38 AM
redboost10
Jan 21, 2004 04:03 PM
USDMMARK
Oct 14, 2003 08:01 AM
