to Gutt cat, or not?
Old Jun 20, 2002 | 09:56 AM
ezark's Avatar
Default to Gutt cat, or not?
have a 3" carsound cat 94000... would it be benficial to gutt it for some HP, or would some turbulence occur (resulting in worse air flow)?
Old Jun 20, 2002 | 09:57 AM
Spade's Avatar
Default Re: to Gutt cat, or not? (gsR-T mode)
NOT....that is a high flow cat.
Just take the cat off and make a test pipe.
Old Jun 20, 2002 | 10:20 AM
ezark's Avatar
Default Re: to Gutt cat, or not? (Spade)
i live in the wonderful state of california. i don't think the test pipe is an option.
Old Jun 20, 2002 | 10:21 AM
ezark's Avatar
atleast not for daily driving.
Old Jun 20, 2002 | 10:25 AM
ion_four's Avatar
if you gut it your car will sound like it doesn't have a cat and you'll probably get pulled over, especially with a bit of smoke comin out at WOT...I wouldn't bother, really. It'll pass visual, but if you have to get tested again you'll need to buy a new one. http://www.testpipe.com has straightpipes that have stock cat heat shields, if you really want to do it right.
Old Jun 20, 2002 | 11:18 AM
Etylorcen's Avatar
Default Re: to Gutt cat, or not? (PS2)
3'' carsound cat flows almost as well as a test pipe so by gutting the cat im sure you'll have worse flow.
Old Jun 20, 2002 | 04:35 PM
ezark's Avatar
Default Re: to Gutt cat, or not? (Etylorcen)
k, thanks guys!
Old Jun 20, 2002 | 06:57 PM
SIK IN DA HED's Avatar
New User
really? is that proven?
Old Jun 20, 2002 | 08:00 PM
SlowB16's Avatar
Default Re: to Gutt cat, or not? (dlplayboy)
take the bitch out
Old Jun 20, 2002 | 11:52 PM
Etylorcen's Avatar
Someone posted cfm charts of a bunch of cats and test pipes and the 3'' carsound cat was so close to the 3'' test pipe is wasnt even funny. The test pipe flowed like 20 cfm more if my memory serves me correctly.
Old Jun 21, 2002 | 12:00 AM
R-1303's Avatar
I'm right there with you!! daam chp fockers!
Old Jun 21, 2002 | 12:14 AM
Anthony K's Avatar
New User
Default Re: to Gutt cat, or not? (R-1303)
Pussies.
Old Jun 21, 2002 | 01:47 AM
DigitalFusion's Avatar
Default Re: to Gutt cat, or not? (Anthony K)
what about gutting stock cats? Is it better to just cut the flanges off and weld a test pipe in? Does the larger hallowed out chamber of a gutted cat create turbuance? Atleast thats what I am beinging to get from ther posts on here
Old Jun 21, 2002 | 02:08 AM
Etylorcen's Avatar
Default Re: to Gutt cat, or not? (CustomCockpits)
I havent actually seen a dyno of a gutted cat but I've been told that it often decreases flow.
Old Jun 21, 2002 | 06:55 AM
98Psi ITR's Avatar
the butt dyno seemed to pick up nice gains upon gutting the stock cat.
Old Jun 21, 2002 | 06:57 AM
98Psi ITR's Avatar
What? If the carsound/magnaflow cat flows almost as well as a test pipe then you can't have worse flow from taking out the restriction.
I would not gut the cat if you are in CA. Get a test pipe.
Old Jun 21, 2002 | 10:12 AM
New User
Default Re: to Gutt cat, or not? (98Psi ITR)
the butt dyno? what is that?
i figured a gutted cat would do better. the whole "bottleneck" turbulence concept makes me wonder though.
Boostage
Jul 1, 2005 11:20 AM
blu2ksi
Jan 15, 2004 12:57 PM
Audio28
Nov 16, 2002 03:38 PM
KooK
Jun 25, 2002 10:03 PM
Bbasso
Dec 26, 2001 08:50 AM
