Turbo Gaskets?
The only two gaskets you really need are the wastegate gaskets and the head/manifold gasket. You do not need the gasket that goes between the manifold and then turbo....ONLY if both surfaces are flat. If they are distorted, then get them machined flat and don't worry about the gasket.
If you buy a new tial wastegate, the gaskets you need are supplied in with the wastegate.
hoya_10fintec
Dec 24, 2005 10:37 PM
KStuned
Apr 3, 2002 04:08 PM
