Need help removing two screws
Old Oct 14, 2007 | 07:20 PM
TeamRiskEG6's Avatar
Default Need help removing two screws
well i dont know what they are called but they are the two screws that hold up the igntion steering wheel lock system. is there a special tool or socket to use to tkae these off, from the pic they look to be reusable..
Old Oct 15, 2007 | 07:54 AM
Echo7847's Avatar
Default Re: Need help removing two screws (TeamRiskEG6)
Use a chisel or fine punch to rotate them counterclockwise and unscrew them.
They are low torque breakaway bolts where the head snaps of after a specified amount of torque. New ones are available from the dealer.
Old Oct 15, 2007 | 10:16 AM
mmuller's Avatar
Mad Scientist
Default Re: Need help removing two screws (Echo7847)
or grind a slot and use a flathead impact screw driver
Old Oct 15, 2007 | 06:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">or grind a slot and use a flathead impact screw driver</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">Use a chisel or fine punch to rotate them counterclockwise and unscrew them.
They are low torque breakaway bolts where the head snaps of after a specified amount of torque. New ones are available from the dealer.</TD></TR></TABLE>
thanks, ill try both and see what happendes, i was thinking of just drilling them out and replacing with normal bolts anyways..lol. thanks for the advise
Old Oct 15, 2007 | 06:45 PM
Hybrid96EK's Avatar
Those aren't supposed to be easy to pull out... That would make stealing the car too easy. Use a dremel and put a slot on them, remove them with an impact driver if needed or flat blade screwdriver if they aren't too tight.
Old Oct 16, 2007 | 03:07 PM
BrakeExpert's Avatar
Default Re: Need help removing two screws (Hybrid96EK)
can you file down the sides and get a BIG *** pair of vice grips?
Old Oct 16, 2007 | 05:21 PM
JohnD1079's Avatar
Default Re: Need help removing two screws (BrakeExpert)
wouldnt you need a small pair of vice grips to accomodatwe the tight space?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert &raquo;</TD></TR><TR><TD CLASS="quote">can you file down the sides and get a BIG *** pair of vice grips?</TD></TR></TABLE>
Old Oct 16, 2007 | 08:44 PM
Default Re: Need help removing two screws (JohnD1079)
oh yeah. unless you got a pair of strong needle nose that wont loose grip and somethin to grab em really hard (or brute force it.) otherwise im out of ideas.
gsr-2nr
Aug 22, 2008 09:33 PM
hu
Apr 30, 2007 01:31 PM
xkrntamax
Dec 15, 2005 09:12 PM
.water
Welding / Fabrication
24
Nov 8, 2005 08:50 PM
.jacob
31
Nov 12, 2003 05:00 PM
