crx revs slow
Old Oct 14, 2007 | 06:48 PM
1sikhatch's Avatar
Default crx revs slow
my car has a problem i have a jdm d15b in my crx with the stock pm6 ecu, my car pulls off real lame and then at like 4k prm the rpms goes up quicker and also between shifts i also hear some poppin out the exhaust, wat could be my problem? my friend has the same setup anf if i jus touch the gas pedal it revs so quicker ad his rpm builds real quicker than mine does.
Old Oct 14, 2007 | 07:04 PM
SIred91's Avatar
Rainman
Default Re: crx revs slow (1sikhatch)
Sounds like a timing problem. Check the distributor first, then the cam and crank.
Get a timing light.
Old Oct 14, 2007 | 07:43 PM
DenzComp's Avatar
I've had the same problem with my hatch ever since I went MPFI. Must be when I swapped Dizzys....How much of a difference will I notice if its in time? I've probably been missing out all this time...not thinking MPFI changed all that much....and I've just been outta time...
Old Oct 15, 2007 | 03:38 AM
1sikhatch's Avatar
Default Re: (DenzComp)
timing is on for sure, i will check it with light. its supposed to be at 12 degrees right?
Old Oct 15, 2007 | 08:21 AM
~sp33~'s Avatar
EFB055
Was this something that just happened one day? Or has it been gradual?
Old Oct 15, 2007 | 08:57 AM
cr-x-91's Avatar
i would convert to obd1..car will run way better. its def a timing issue. cars is still allowing fuel in while shifting,then gets burned in cat wich makes that popping sound. to do a full engine conversion will cost like 300 max.
1sikhatch's Avatar
Default Re: (~sp33~)
from the tme i put the motor in my car thats how it was
Old Oct 16, 2007 | 08:46 AM
1sikhatch's Avatar
Default Re: (1sikhatch)
pls help me out
Old Oct 16, 2007 | 08:58 AM
goforbroke's Avatar
MEAT PATTY
How do you know the timing is not off if you always had this problems since you swaped the motor in?
Old Oct 16, 2007 | 09:06 AM
cr-x-91's Avatar
its ur timing bro..way advanced.
Old Oct 16, 2007 | 09:19 AM
Jonknee's Avatar
Default Re: (cr-x-91)
sounds like timing or maybe time for capand rotor change.
Old Oct 16, 2007 | 09:40 AM
kixcrx's Avatar
Default Re: (Jonknee)
it is your timing my car was the same way like two days ago i just fixed the timing and runs better
Old Oct 17, 2007 | 05:21 AM
1sikhatch's Avatar
Default Re: (kixcrx)
copuld it be because i am using the 1.6 ex belt?
Old Oct 17, 2007 | 05:57 AM
Jonknee's Avatar
The ideal timing belt would be the VX belt.
Sunrise21Motors
Honda Civic (2006 - 2015)
Nov 2, 2011 09:15 PM
96 EX
Oct 1, 2008 11:47 AM
LostCRX
Jul 9, 2004 03:55 AM
Jaydeep
Apr 28, 2004 07:15 PM
Jaydeep
Apr 26, 2004 08:43 PM
