Timing problem.
Old Jul 8, 2004 | 01:15 PM
LostCRX's Avatar
Default Timing problem.
I can't adjust my base timing pass 8 degree, even when I have advance the distributor all the way, it will only go up to 8. I was told me distributor is messed up, any idea?
Old Jul 8, 2004 | 02:37 PM
cougar10ag's Avatar
you sure your checking it right with a timing light?
oh BTW you ahve to put your ECU into service mode before making changes.
Old Jul 8, 2004 | 02:59 PM
LostCRX's Avatar
Default Re: (cougar10ag)
i got obd0 so no need for that. im sure im checking it's right.
Old Jul 8, 2004 | 04:25 PM
cougar10ag's Avatar
well there should be nothing wrong with your dizzy. i mean if you move it it'll change the timing cuz it's a physical change, not electronic.
whats the stock timing? 8 seems WAY to low for a honda. sounds like a problem.. any ignition or ECU mods?
Old Jul 9, 2004 | 03:55 AM
JimBlake's Avatar
Are you sure your camshaft timing is OK?
tctruong94
Apr 27, 2017 11:10 AM
zx92027xz
Aug 11, 2012 06:47 AM
downeyballz
Jun 9, 2007 09:47 AM
1SlowSi
May 1, 2004 06:37 AM
Hybridize
Oct 31, 2003 11:31 AM
