car wont go pass 3000rpms
I just installed my turbo today, and now my car wont go pass 3000 rpm. Im on a stock fuel pump with DSM injectors. Im running the stock wastegate pressure which is around 5-6psi. My bov does not go off and when i try to drive pass 3000rpm, the car kinda chokes and feels like its dying
i do have a cel but i dont have access to a scanner. im running uberdata on a p06. do you guys think it could be my injector wiring?
a 3000rpm limit is a dead giveaway that you are in limp mode. The solid CEL is also a giveaway. Either the chip, the ECU, or the program are bad, that's it and that's all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">a 3000rpm limit is a dead giveaway that you are in limp mode. The solid CEL is also a giveaway. Either the chip, the ECU, or the program are bad, that's it and that's all.</TD></TR></TABLE>
so the injectors has nothing to do with it right
you have an ecu / electrical problem. if all of the cylinders are firing then no they have nothing to do with it. the limp mode runs the car horribly rich and it may seem like your injectors are fuxored but that usually isn't the case. focus on the ecu/wiring to the injectors.
im trying to check my wiring, nothing seems wrong with it. should i take a picture of the resistor box wiring and show you guys?
i think the ecu is ok. When i use my stock ecu, the car doesnt even idle well. The tach shows that its only at 100-200 rpms. When i put in the chipped ecu, the car idles at 1000 and sounds normal. Could it be that the chip and ecu are fine, but the tuning sucks?
