ls rebuild, bearing question
how would i go about finding out the size bearings that was in my block.
on the crank it said b2 b2 a2 a2 and on the block it was printed cccdd.
how do i know what rod bearings to use and what main bearings to use? anyhelp would greatly appreciated;. thanks
The bearings should be marked with the color associated with the letter.
http://www.sonsacuraparts.com/...dIrno=
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcrx16 »</TD></TR><TR><TD CLASS="quote"> b2 b2 a2 a2 and on the block it was printed cccdd.
how do i know what rod bearings to use and what main bearings to use? anyhelp would greatly appreciated;. thanks</TD></TR></TABLE>
b2 is a yellow bearing and a2 is a pink bearing im 100% on this one i just changed my bearings on my rod but im not sure about the crank bearing if you find out how to do this let me know because im rebuilding my block next week and im gonna get all new bearings
From the link above.
13211-PR4-A01 BEARING A, CONNECTING ROD (BLUE) (DAIDO)
13211-PR4-A02 BEARING A, CONNECTING ROD (BLUE) (TAIHO)
13212-PR4-A02 BEARING B, CONNECTING ROD (BLACK) (TAIHO)
13213-PR4-A01 BEARING C, CONNECTING ROD (BROWN) (DAIDO)
13213-PR4-A02 BEARING C, CONNECTING ROD (BROWN) (TAIHO)
13214-PR4-A02 BEARING D, CONNECTING ROD (GREEN) (TAIHO)
13215-PR4-A01 BEARING E, CONNECTING ROD (YELLOW) (DAIDO)
13215-PR4-A02 BEARING E, CONNECTING ROD (YELLOW) (TAIHO)
13216-PR4-A01 BEARING F, CONNECTING ROD (PINK) (DAIDO)
13216-PR4-A02 BEARING F, CONNECTING ROD (PINK) (TAIHO)
13217-PR4-A02 BEARING G, CONNECTING ROD (RED) (TAIHO)
13321-PR3-004 BEARING A, MAIN (UPPER) (BLUE)(TAIHO)
13322-PR3-003 BEARING B, MAIN (UPPER) (BLACK) (DAIDO)
13322-PR3-004 BEARING B, MAIN (UPPER) (BLACK) (TAIHO)
13323-PR3-003 BEARING C, MAIN (UPPER) (BROWN) (DAIDO)
13323-PR3-004 BEARING C, MAIN (UPPER) (BROWN) (TAIHO)
13324-PR3-003 BEARING D, MAIN (UPPER) (GREEN) (DAIDO)
13324-PR3-004 BEARING D, MAIN (UPPER) (GREEN) (TAIHO)
13325-PR3-004 BEARING E, MAIN (UPPER) (YELLOW) (TAIHO)
13326-PR3-003 BEARING F, MAIN (UPPER) (PINK)(DAIDO)
13326-PR3-004 BEARING F, MAIN (UPPER) (PINK)(TAIHO)
13327-PR3-003 BEARING G, MAIN (UPPER) (RED) (DAIDO)
13327-PR3-004 BEARING G, MAIN (UPPER) (RED) (TAIHO)
13341-PR3-003 BEARING A, MAIN (LOWER) (BLUE)(DAIDO)
13341-PR3-004 BEARING A, MAIN (LOWER) (BLUE)(TAIHO)
13342-PR3-003 BEARING B, MAIN (LOWER) (BLACK) (DAIDO)
13342-PR3-004 BEARING B, MAIN (LOWER) (BLACK) (TAIHO)
13343-PR3-003 BEARING C, MAIN (LOWER) (BROWN) (DAIDO)
13343-PR3-004 BEARING C, MAIN (LOWER) (BROWN) (TAIHO)
13344-PR3-003 BEARING D, MAIN (LOWER) (GREEN) (DAIDO)
13344-PR3-004 BEARING D, MAIN (LOWER) (GREEN) (TAIHO)
13345-PR3-003 BEARING E, MAIN (LOWER) (YELLOW) (DAIDO)
13345-PR3-004 BEARING E, MAIN (LOWER) (YELLOW) (TAIHO)
13346-PR3-003 BEARING F, MAIN (LOWER) (PINK)(DAIDO)
13346-PR3-004 BEARING F, MAIN (LOWER) (PINK)(TAIHO)
13347-PR3-003 BEARING G, MAIN (LOWER) (RED) (DAIDO)
13347-PR3-004 BEARING G, MAIN (LOWER) (RED) (TAIHO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0tgot »</TD></TR><TR><TD CLASS="quote">you definatly want to go ACL if youwant LS/vtec in the future....</TD></TR></TABLE>
no, you dont. you want to use whatever bearings give you the correct clearances, oem or otherwise. ACL's are equivalent to honda's green, or middle, bearing. sometimes they work, sometimes not.
are all cranks the same? if i put pistons and onnectings rods from one engine into another engine would that change the bearings size or clearnaces?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcrx16 »</TD></TR><TR><TD CLASS="quote"> if i put pistons and onnectings rods from one engine into another engine would that change the bearings size or clearnaces?
yes. each crank has different bearing sizes cast onto them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
no, you dont. you want to use whatever bearings give you the correct clearances, oem or otherwise. ACL's are equivalent to honda's green, or middle, bearing. sometimes they work, sometimes not.</TD></TR></TABLE>
Listen to this guy. And I would personally only use Honda bearings, they are famous for making great bearings.
what is the difference btwn TAIHO vs DAIDO in bearings. when i look on the acura parts webpage it list the same bearings but one says taiho and the other says daido? whats the difference
and i have a crank and a set of stock rods from another engine, what connecting rod bearings do i use?> do i use the ones stamped on the crank or do i use the one stamped on the crank that the rods were originally attached to. i have two cranks and one is in better shape. please advise......
ok the previous may be a little confusing. i have a engine in my car with a crank that is in great condition. i also have a block sitting around. i had lost the connecting rod caps from the engine in the car so i was wodering if i could take out the piston and rod out of the block sitting around and put those rods and pistons in the engine in the car on that crank and the question i wanted to know what if i put those rod and pistons in the car engine do i use the bearing code stamped on the crank thats in the car now or do i use the codes on the crank in the block thats sitting around?
and just to make certain, the rod bearings code is on the crank next to the rod journals right? and they go sumthin like b2 b2 a2 a2 right?
