Throttle Cable?
Has anyone tried tightening up their throttle cable, I've heard this can improve throttle response a bit, but can also cause idle problems. Is this worthwhile to do or is it just a waste of time?
There is a little improvement to be had, but nothing extraordinary. Just takes the slop out of the pedal. If you adjust it right, there is no downside and idle will be fine.
it's easy to adjust right? I think just 2 screws need to be loosend and then adjust a single set screw...Is this correct? I've heard that tightening it up to about half of the slack...if that makes sense...is usually a good setting, thanks for the info.
it's 2 nuts, no set screw. Yea I suppose just half slack. Just look at the valve, goal is to have it as tight as possible and still have the valve wheel come back and hit the stop.
If you do like sackd said and make sure it still hits the stop that will work, but to avoid idle problems make sure it still rests where it is now. With no weight on the pedal you want the throttle plate to be in the same position, you just want to get rid of the slack in the cable.
I found it made the car better to drive without the slop in the pedal.
Good luck!
Good luck!
I was able to get 25whp out of this mod
Was that just in the midrange or top end?
j/k
cool i bet that will also help eliminate turbo lag on ITR's ..right ?
EDIT: A nice 4-1 header really helps out with turbo lag too
[Modified by AssPenny, 1:49 PM 6/20/2002]
That is true, due to the fact the the butterfly can open faster thus allowing the turbo to spool up faster... Its the best mod I've ever done
Damn, and I spent like 3,000 dollars just to get 25 hp and you did it for free.
You should also lash your valves to .0001 This allows them to open faster and stay open longer... good for atleast 5whp
For sure, I don't want to lay my toe on the peddle and jump up to WOT and snap the cable in 2, I'll just adj. the slack to be a little bit tighter than it is now and go from there. Thanks again
SLURS
Jun 30, 2009 08:29 AM
