Throttle Cable?
Old Jun 20, 2002 | 06:46 AM
Nate B's Avatar
Default Throttle Cable?
Has anyone tried tightening up their throttle cable, I've heard this can improve throttle response a bit, but can also cause idle problems. Is this worthwhile to do or is it just a waste of time?
Old Jun 20, 2002 | 06:48 AM
sackdz's Avatar
Default Re: Throttle Cable? (KILLERB18)
There is a little improvement to be had, but nothing extraordinary. Just takes the slop out of the pedal. If you adjust it right, there is no downside and idle will be fine.
Old Jun 20, 2002 | 06:52 AM
Nate B's Avatar
Default Re: Throttle Cable? (sackdz)
it's easy to adjust right? I think just 2 screws need to be loosend and then adjust a single set screw...Is this correct? I've heard that tightening it up to about half of the slack...if that makes sense...is usually a good setting, thanks for the info.
Old Jun 20, 2002 | 06:56 AM
sackdz's Avatar
it's 2 nuts, no set screw. Yea I suppose just half slack. Just look at the valve, goal is to have it as tight as possible and still have the valve wheel come back and hit the stop.
Old Jun 20, 2002 | 07:18 AM
CW_97_ITR's Avatar
If you do like sackd said and make sure it still hits the stop that will work, but to avoid idle problems make sure it still rests where it is now. With no weight on the pedal you want the throttle plate to be in the same position, you just want to get rid of the slack in the cable.
I found it made the car better to drive without the slop in the pedal.
Good luck!
Old Jun 20, 2002 | 08:29 AM
sgT's Avatar
sgT
Default Re: Throttle Cable? (CW_97_ITR)
Keep in mind if you do this, you will eventually stretch the cable and have to
do this again.
Old Jun 20, 2002 | 09:09 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Throttle Cable? (sgT)
sensitive throttle =
Old Jun 20, 2002 | 09:33 AM
BudMan's Avatar
Default Re: Throttle Cable? (dLo GSR)
10mm play in the cable is nicey nice....time to tighten mine again.
The first time I checked mine, it was ~25mm play in the middle of the cable
Old Jun 20, 2002 | 09:38 AM
MPH's Avatar
MPH
New User
If you drag you will cut good rt's
Old Jun 20, 2002 | 09:42 AM
AssPenny's Avatar
Default Re: Throttle Cable? (MPH)
I was able to get 25whp out of this mod
Old Jun 20, 2002 | 09:43 AM
MPH's Avatar
MPH
New User
Default Re: Throttle Cable? (AssPenny)
Was that just in the midrange or top end?
Old Jun 20, 2002 | 09:44 AM
AssPenny's Avatar
Midrange, do to the faster throtle response, it picked up almost 25 in the mids, and since i got there faster, i was able to pick up almost 14 peak
Old Jun 20, 2002 | 09:45 AM
TsunamiZC's Avatar
cool i bet that will also help eliminate turbo lag on ITR's ..right ? j/k
Old Jun 20, 2002 | 09:47 AM
AssPenny's Avatar
Default Re: Throttle Cable? (tsunami_zc)
That is true, due to the fact the the butterfly can open faster thus allowing the turbo to spool up faster... Its the best mod I've ever done
EDIT: A nice 4-1 header really helps out with turbo lag too
[Modified by AssPenny, 1:49 PM 6/20/2002]
Old Jun 20, 2002 | 09:49 AM
MPH's Avatar
MPH
New User
Damn, and I spent like 3,000 dollars just to get 25 hp and you did it for free.
Old Jun 20, 2002 | 09:51 AM
AssPenny's Avatar
You should also lash your valves to .0001 This allows them to open faster and stay open longer... good for atleast 5whp
Old Jun 20, 2002 | 09:55 AM
MPH's Avatar
MPH
New User
Mine are set at -0007, -0008 and clicks all day long, but the butt dyno says I picked up hp from 3000 to 3100rpm.
Old Jun 20, 2002 | 10:14 AM
Nate B's Avatar
Thanks for the info guys, looks like I got some work to do when I get home. I'll let you know how it turned out.
Old Jun 20, 2002 | 10:15 AM
MPH's Avatar
MPH
New User
Don't go to tight, leave a little slack.
Old Jun 20, 2002 | 10:27 AM
Nate B's Avatar
For sure, I don't want to lay my toe on the peddle and jump up to WOT and snap the cable in 2, I'll just adj. the slack to be a little bit tighter than it is now and go from there. Thanks again
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
dangercartjason
Classic Hondas
Aug 16, 2011 08:47 PM
cdmef
Jul 3, 2011 06:03 AM
SLURS
Jun 30, 2009 08:29 AM
GruvyTune
Aug 18, 2001 09:15 AM
