Motor Mounts
Old Oct 12, 2007 | 12:11 PM
NAmodified's Avatar
Default Motor Mounts
I have a dc2.
There are 5 mounts.
3 top motor mounts(engine, trans, and rear)
2 lower motor mounts
I was told u only need the 3 top motor mounts, and the bottom 2 arent really necessary. is that true?
Old Oct 12, 2007 | 12:23 PM
doood's Avatar
been there done that
Default Re: Motor Mounts (NAmodified)
they wouldnt be there if they werent necessary. now if you were using aftermarket mounts like hasport or avid you wouldnt need the lower torque mounts.
Old Oct 12, 2007 | 01:28 PM
integra686's Avatar
the 3 are the main ones. if u get race mount they "say" you can get rid of others, but heard that casues more vibrations throughout car :/
my op: keep all 5.
Old Oct 12, 2007 | 02:13 PM
NAmodified's Avatar
Default Re: Motor Mounts (integra686)
wat about if I have inserts for the mounts? Its the same as upgraded mounts.
Old Oct 12, 2007 | 02:14 PM
doood's Avatar
i'd keep them and get inserts for them too
Old Oct 12, 2007 | 03:00 PM
myfirstdc2's Avatar
i would keep all five mounts. as they mentioned before, u can run with just the 3. but it does tend to vibrate more. just keep it stock and do inserts . i have the replacements on mine (hasport) and i didnt really like it to much so i put back on the lower torques with inserts and now it's bomb diggity u know?
Modified by myfirstdc2 at 4:21 PM 10/12/2007
Old Oct 12, 2007 | 03:16 PM
Turbo-GSR1287's Avatar
Default Re: Motor Mounts (myfirstdc2)
Jim Fab ftw
Old Oct 15, 2007 | 07:53 AM
NAmodified's Avatar
Default Re: Motor Mounts (Turbo-GSR1287)
they dont make inserts for the lower mounts. if so where can I get them?
Old Oct 15, 2007 | 11:23 AM
91redteg's Avatar
what would be the pooint of removing them?
Old Oct 15, 2007 | 12:04 PM
dizzzane's Avatar
What is making you want to ditch the two lower mounts? As doood said, if they are there, they are necessary.
Old Oct 15, 2007 | 04:48 PM
B.J.'s Avatar
I would use all the mount honda did'nt put them on there for no reason.
Old Oct 16, 2007 | 06:13 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified &raquo;</TD></TR><TR><TD CLASS="quote">they dont make inserts for the lower mounts. if so where can I get them?</TD></TR></TABLE>
yeah they do. i had them. http://cgi.ebay.com/ebaymotors...wItem . this includes the back mount and 2 lower sides mounts. the 2 top side mounts come in a separate kit.
Old Oct 16, 2007 | 08:35 AM
nate_2k5's Avatar
Default Re: Motor Mounts (vladd)
i am running hasport/jimfab tq mounts and it vibrates quite a bit mostly due to the tq mounts. don't get rid of the tq mounts
dafreeeze
19
May 14, 2013 04:33 PM
SweetSIReX
Dec 19, 2008 05:05 PM
hondaapi
Oct 20, 2008 01:52 AM
D16SohcVtec
Aug 12, 2008 08:03 AM
Bbasso
Mar 4, 2005 05:48 PM
